Air compressors - help?, an education |
VaccaRabite |
Dec 26 2006, 06:51 PM
En Garde! Group: Admin Posts: 13,554 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So I went to Home Depot today, armed with some scratch and the will to buy an air compressor and a DA air sander.
HD sells the husky line. So, I went to the tools, found a DA sander (Husky, needed 4cfm @ 90psi, and the box said it would work continously with 20+ gallon compressors). Then I walked over to look at compressors. They had a Husky 24 gallon compressor that flowed 5.1 cfm @ 90 pis on sale ($225). Score! but then, on top of the motor, was a little chart with reccomended tools and non-reccomneded tools. All sanders and DA sanders were non-reccomneded. I called over a HD floor guy, who called over another 2 guys, and we could not see a good reason for the prohibition. But, we decided that if the factory did not reccomend it, then it should not be used as such, and I walked over to the electric tool section and bought an electric DA sander. (IMG:style_emoticons/default/sad.gif) I am going to need to buy a compressor by the spring. I'm clearly in the "hobbiest" catagory, and may not use the tool again for a long time aftyer I am done with my 914, but when it comes time to paint, it will probably be cheaper for me to buy one then rent one - given the slow nature that I work. I want to know why the sander was not reccomended, when the compressor could flow the air and had a big enough tank according to the tool. I have theories, but I thought somone here might be able to give better advice. Thanks Zach |
PRS914-6 |
Dec 26 2006, 07:15 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
The problem with a $225.00 compressor is you get what you pay for. It's "non industrial" so you can't run it all day every day.....A big tank only gets you a reserve. If you run a sander a lot and suck the tank down, the compressor will run and run and they are just not designed to take it. For impacts ratchets, no problem, they don't draw much. A small job using a sander would be OK just not big multiple projects.
Personally, I use a 5 hp 220V industrial model with a large tank but I have a bead blaster and other high demand air tools. |
Lo-Fi Version | Time is now: 28th September 2024 - 07:14 AM |
