VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,478 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
So I went to Home Depot today, armed with some scratch and the will to buy an air compressor and a DA air sander.
HD sells the husky line. So, I went to the tools, found a DA sander (Husky, needed 4cfm @ 90psi, and the box said it would work continously with 20+ gallon compressors). Then I walked over to look at compressors. They had a Husky 24 gallon compressor that flowed 5.1 cfm @ 90 pis on sale ($225). Score! but then, on top of the motor, was a little chart with reccomended tools and non-reccomneded tools. All sanders and DA sanders were non-reccomneded. I called over a HD floor guy, who called over another 2 guys, and we could not see a good reason for the prohibition. But, we decided that if the factory did not reccomend it, then it should not be used as such, and I walked over to the electric tool section and bought an electric DA sander. (IMG:style_emoticons/default/sad.gif) I am going to need to buy a compressor by the spring. I'm clearly in the "hobbiest" catagory, and may not use the tool again for a long time aftyer I am done with my 914, but when it comes time to paint, it will probably be cheaper for me to buy one then rent one - given the slow nature that I work. I want to know why the sander was not reccomended, when the compressor could flow the air and had a big enough tank according to the tool. I have theories, but I thought somone here might be able to give better advice. Thanks Zach |
VaccaRabite |
I am limited power wise. I only have 110 going to the garage (which is detached), running a 220 circut there (I'd love to do it) would require trenching under my driveway.
Anything that I buy won't be used all day everyday. After the 914 is done, the next task would be running a floor nailer as I continue to lay new flooring down in the house. Mayhaps I'll go check out HF tomorrow and see what they are offering. I like having the week off. i need to do this more often. :-) Zach |
Lo-Fi Version | Time is now: 27th June 2024 - 07:09 PM |
