Painting questions, what nap roller to use? |
swood |
Nov 11 2003, 12:01 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Just Kidding.
I'm cleaning out the engine bay, pretty much sanding down all the glue, removing all the dirt and wire brushing out the rust (just surface, no deep rust). The side and rear panels don't need much in the way of repair, so, can I just lightly sand them and tack cloth it to prepare it to recieve paint? I have a self etching primer for the firewall that's going on nice and smooth. My color is Palma Green Metallic. I'm not sure if metallics are meant to be color sanded much, if at all. I guess that question is more for the exterior, the bay I'm using a single stage paint, so as long as it doesnt run I probably won't worry about the sanding. |
thesey914 |
Nov 12 2003, 02:20 AM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Kageek, what kind of respirator would you recommend? I've done some research on paints and from what I've read epoxy primer is the way to go, really tough and protective and sticks to any thing.
Are the replaceable canister filters safe for isocyanides (sp?) like this ... or do you need an air-fed mask Attached image(s) |
Lo-Fi Version | Time is now: 25th June 2024 - 11:12 PM |
