Crap, ordered the wrong ball joint, Need some advice.... |
jr91472 |
Dec 27 2006, 03:56 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I need to replace the ball joints that go on the end of the tie rods, but instead I ordered the ball joint that mounts the suspension to the A-arm. (IMG:style_emoticons/default/dry.gif)
I am trying to tighten up my steering as it feels a bit wobbly and I can see "looseness" at the tie rod ends. But the question now is: should I go ahead and do the other ball joints since I have them. I don't "think" the A-arm ball joints are bad, but honestly I am not sure how to tell if they are or not. Is this a big job? Sounds like I need a special tool. What other hardware is required? help! |
Cap'n Krusty |
Dec 27 2006, 04:03 PM
What you want are "tie rod ends". They're not called "ball joints" in that application. If you have the correct ball joints for your car, and you can't return them, you might as well replace 'em. BE SURE you have the right ones! Early vs. late, and they DON'T interchange. The Cap'n
Lo-Fi Version | Time is now: 24th June 2024 - 07:08 AM |
