Crap, ordered the wrong ball joint, Need some advice.... |
jr91472 |
Dec 27 2006, 03:56 PM
"I'm pacing myself sergeant..." Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 |
I need to replace the ball joints that go on the end of the tie rods, but instead I ordered the ball joint that mounts the suspension to the A-arm. (IMG:style_emoticons/default/dry.gif)
I am trying to tighten up my steering as it feels a bit wobbly and I can see "looseness" at the tie rod ends. But the question now is: should I go ahead and do the other ball joints since I have them. I don't "think" the A-arm ball joints are bad, but honestly I am not sure how to tell if they are or not. Is this a big job? Sounds like I need a special tool. What other hardware is required? help! |
dakotaewing |
Dec 27 2006, 06:09 PM
Senior Member Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region |
JR -
If you are going to replace the ball joints, you need to determine if your struts are the pinch bolt type... If they are, you will also need 2 pinch bolts for the ball joints... Everything I have read says to replace them, not reuse them... I am currently doing this myself... TE |
Lo-Fi Version | Time is now: 25th September 2024 - 11:03 PM |
