jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
I need to replace the ball joints that go on the end of the tie rods, but instead I ordered the ball joint that mounts the suspension to the A-arm. (IMG:style_emoticons/default/dry.gif)
I am trying to tighten up my steering as it feels a bit wobbly and I can see "looseness" at the tie rod ends. But the question now is: should I go ahead and do the other ball joints since I have them. I don't "think" the A-arm ball joints are bad, but honestly I am not sure how to tell if they are or not. Is this a big job? Sounds like I need a special tool. What other hardware is required? help! |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
JR -
If you are going to replace the ball joints, you need to determine if your struts are the pinch bolt type... If they are, you will also need 2 pinch bolts for the ball joints... Everything I have read says to replace them, not reuse them... I am currently doing this myself... TE |
jr91472 |
JR - If you are going to replace the ball joints, you need to determine if your struts are the pinch bolt type... If they are, you will also need 2 pinch bolts for the ball joints... Everything I have read says to replace them, not reuse them... I am currently doing this myself... TE No worries, not only did I order the wrong ball joints, but I also order the corresponding wrong hardware (IMG:style_emoticons/default/chairfall.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 07:29 AM |
