runfaster |
Newbie ![]() Group: Members Posts: 47 Joined: 29-March 06 From: oregon Member No.: 5,789 ![]() |
Ok guys-i need help with installing the rear main seal. replaced once with stock ering with no special procedures and it leaked. replaced with stock victor reinz with a light coat of hondabond(let set up for 3 days) and it leaked.
what is the trick here? 1. The ering was a little bit thinner than the victor reinz-10mm vs. 11.5mm. 2. The original was an ering. 3. Is there a special method for using permetex or the hondabond type of sealent? Any help would be appreciated, because i have been working on this pos for about 9 months and i am running out of stuff to replace. i am so close to having a daily runner, but i can't get this seal right.......HELP.......... Thanks, craig |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
When installing those the seal and flywheel o-ring, I've never used anything but a liberal application of motor oil.
Before you install the next seal, run your finger around the mating surface. Make sure there are no burrs or gouges that could cause a leak. If there are... well... let's hope there's not. That seal has a tight fit. Make sure you drive it in straight... not tilted at any time. Good luck and please post what you find when you get inside again! Cheers, Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:52 PM |
