Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
I finally got the interior out and removed the rocker panels and bumpers. Here's what I found:
The right side: Attached image(s) ![]() ![]() |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
I've seen people here repair far worse.....good example of why you should clean behind the rocker covers....how's the hell hole?
Cevan |
I've seen people here repair far worse.....good example of why you should clean behind the rocker covers....how's the hell hole? I haven't started to clean the engine compartment yet. The battery tray is rusted but the support for it seems fine. I've poked around underneath the supprt and couldn't find any major problems. The metal behind the rockers is called the inner rocker or the logitudinal? |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
The metal behind the rockers is called the inner rocker or the longitudinal? that is called the inner rocker which makes up the clam shell that makes the longitudinal. Shop here |
Lo-Fi Version | Time is now: 24th June 2024 - 11:55 PM |
