Any reason to *not* buy this inexpensive Metal Cutting Band Saw... |
Mid_Engine_914 |
Dec 29 2006, 10:19 PM
Member Group: Members Posts: 195 Joined: 22-September 06 From: Left Coast Member No.: 6,888 |
to cut steel tubing? I will probably only need to use it a few times a year but I want to make sure it makes accurate mitered cuts...
(IMG:http://ec1.images-amazon.com/images/P/B0000AXAYK.01-A1787XOD7Q2I4M._SS500_SCLZZZZZZZ_V39379494_.jpg) http://www.amazon.com/Northern-Industrial-...e=UTF8&s=hi |
PRS914-6 |
Dec 29 2006, 11:09 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I have a Wilton that is similar. I've used it for years. Two suggestions...
1. DO NOT BUY CHEAP BLADES! You won't find good ones at HF or similar and don't be surprised if a good one cost $15.00-$20.00 2. If you are cutting all thin tubing, get a fine toothed blade. Rule of thumb....3 teeth on the metal. Your blades will llast longer. |
Lo-Fi Version | Time is now: 6th January 2025 - 04:19 PM |
