Mallory unilite, rebuild kits? |
scotty b |
Dec 29 2006, 09:41 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Can't find anything on google so I'm asking youz guyz. Is there a rebuild kit for the Unilite? I have one that was part of a VW parts purchase, looks a little rough but definitely rebuildable for a D.D. or toy. My biggest issue is the wiring was cut just outside of the housing. I could solder on some new pieces but is there any point? Could the trigger be damaged by the heat generated with the soldering iron?
Aaron Cox |
Dec 30 2006, 12:06 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
the optical triggers are replacable... 90 bucks. they are the same pickup for all their unilites...
i fried one on accident (as did mueller (IMG:style_emoticons/default/poke.gif)) and they are replacable. |
Mueller |
Dec 30 2006, 12:35 AM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
the optical triggers are replacable... 90 bucks. they are the same pickup for all their unilites... i fried one on accident (as did mueller (IMG:style_emoticons/default/poke.gif)) and they are replacable. it's a very basic circuit, about $5 in parts....I've opened up my fried part and just need to figure out what went "poof", should be easy to figure out once I get a-round-tuit (IMG:style_emoticons/default/wink.gif) I know Jake loves the Mallory and I think he has mentioned the only failures he has had was due to voltage spikes....Mallory sells a $30 or so device to protect from such things (I have one installed on mine, but it won;t prevent hooking up the + and - incorrectly (IMG:style_emoticons/default/blink.gif) ) |
Aaron Cox |
Dec 30 2006, 12:42 AM
the optical triggers are replacable... 90 bucks. they are the same pickup for all their unilites... i fried one on accident (as did mueller (IMG:style_emoticons/default/poke.gif)) and they are replacable. it's a very basic circuit, about $5 in parts....I've opened up my fried part and just need to figure out what went "poof", should be easy to figure out once I get a-round-tuit (IMG:style_emoticons/default/wink.gif) I know Jake loves the Mallory and I think he has mentioned the only failures he has had was due to voltage spikes....Mallory sells a $30 or so device to protect from such things (I have one installed on mine, but it won;t prevent hooking up the + and - incorrectly (IMG:style_emoticons/default/blink.gif) ) i accidently lost the POS batt terminal mid drive... so the current coming out of the alternator didnt go into the battery... it went into all the wires that were hooked up to that terminal..... gee... into the dizzy (yes mine is wired differently do to a CDI box based ignition.) |
Lo-Fi Version | Time is now: 6th January 2025 - 08:29 PM |
