Any reason to *not* buy this inexpensive Metal Cutting Band Saw... |
Mid_Engine_914 |
Dec 29 2006, 10:19 PM
Member Group: Members Posts: 195 Joined: 22-September 06 From: Left Coast Member No.: 6,888 |
to cut steel tubing? I will probably only need to use it a few times a year but I want to make sure it makes accurate mitered cuts...
(IMG:http://ec1.images-amazon.com/images/P/B0000AXAYK.01-A1787XOD7Q2I4M._SS500_SCLZZZZZZZ_V39379494_.jpg) http://www.amazon.com/Northern-Industrial-...e=UTF8&s=hi |
ChrisFoley |
Dec 30 2006, 07:22 AM
I am Tangerine Racing Group: Members Posts: 7,970 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I used to have three of them at my shop until I bought a nice big saw. I still use one at the shop and have one at home as well.
They do not cut straight and the angle adjusting slot isn't well formed. The sheet metal support frame sucks, and the motor plate isn't sturdy enough. and so on... All of these issues can be dealt with if you are patient. One of the most useful upgrades I recommend is a better support frame made with square tubing. I also agree about the blade quality. You could buy a 100 ft coil of 1/2" wide Starrett bimetal blade material in a couple of tooth pitches, then find a fabrication shop with a blade welder. Paying them to weld blades should be cheaper than buying finished blades. I think you can get 18 blades from 100 ft. |
PRS914-6 |
Dec 30 2006, 09:18 AM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I also agree about the blade quality. You could buy a 100 ft coil of 1/2" wide Starrett bimetal blade material in a couple of tooth pitches, then find a fabrication shop with a blade welder. Paying them to weld blades should be cheaper than buying finished blades. I think you can get 18 blades from 100 ft. Tha't exactly what I do. Last roll cost $220.00 but each blade lasts a LONG time. A Harbor Freight blade lasts me about one day |
Lo-Fi Version | Time is now: 6th January 2025 - 04:09 PM |
