Big Bore Kits |
Big Bore Kits |
PORobinSCHE |
Dec 30 2006, 09:33 PM
Member Group: Members Posts: 421 Joined: 22-July 06 From: Orlando,Fl Member No.: 6,484 |
is there a big bore kit that will drop into a 1.7 litre motor. one that doesn't require machining?
thank you Robin |
McMark |
Dec 30 2006, 10:01 PM
Not quite George. There is a 96 mm piston and cylinder set that will drop into a 1.7. There are two issues with doing this, the cylinder heads, as mentioned, and the wrist pin height. If you try to put pistons designed for a 2.0 onto a 1.7 you will have deck height issues. You must get pistons designed for a 66 mm stroke crank (stock 1.7).
I believe these are the right ones but you should email them to make sure before ordering. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:09 AM |
