> Look y'all, I done welded iyut., My first try...
SGB
post Jan 2 2007, 05:41 PM
just visiting
OK. It looks AWFUL. JUST AWFUL. But thes pieces are really and fully attached. Even actually fused like real welding in a few spots. I'm gonna keep practicing a little before I attempt car stuff, I think. (IMG:style_emoticons/default/smile.gif)
For a cheapie HF wire feed (not mig), it seems to work OK. Who has some good welding tips? I saw something on the almighty internet that indicated there might be primer of some kind? When do ya use this? What do I need to look out for? It's kinda fun. The biggest challenge is starting "in the dark". How easy is it to burn 914 sheet metal up? This is only a two setting unit- high or low. So far I've been using just low.
So here is my sculpture.
Now I really need a good cut-off tool....
Crazyhippy
post Jan 2 2007, 08:30 PM
Insert witty comment here...
yes you can weld upside down, burns are a bitch, but they make coats to helps.
BJH
SGB   Look y'all, I done welded iyut.   Jan 2 2007, 05:41 PM
McMark   It's a start! :D The Harbor Freight auto...   Jan 2 2007, 05:58 PM
Heeltoe914   :agree: It's a start! :D The Harbor F...   Jan 2 2007, 06:22 PM
JPB   Its flux core wire right? For mild steel I think ...   Jan 2 2007, 06:35 PM
SGB   Thanks folks. The auto darkening helmet sounds li...   Jan 2 2007, 08:10 PM
Vacca Rabite   So far all of the welding that I have done on my c...   Jan 2 2007, 08:22 PM
Crazyhippy   yes you can weld upside down, burns are a bitch, b...   Jan 2 2007, 08:30 PM
nebreitling   just my 02: don't go near your car with that ...   Jan 2 2007, 09:14 PM
SGB   use it for mending fence or fixing a plow or som...   Jan 2 2007, 09:22 PM
PRS914-6   If you are going to try to weld body parts with an...   Jan 2 2007, 09:29 PM
alpha434   Get a welding book. It helps to pre-heat the work...   Jan 2 2007, 09:44 PM
andys   And DON'T get a crappy auto-darkening helmet...   Jan 2 2007, 09:57 PM
McMark   And DON'T get a crappy auto-darkening helmet ...   Jan 3 2007, 12:38 AM
Air_Cooled_Nut   ...And DON'T get a crappy auto-darkening helm...   Jan 3 2007, 02:29 PM
Krieger914   The HF helmut is $50. I took a welding class...   Jan 2 2007, 10:21 PM
John   If you are using wire feed (not MIG) then you shou...   Jan 2 2007, 10:39 PM
highways   Either go with a quality auto darkening or a quali...   Jan 3 2007, 01:46 AM
John Kelly   Try welding with no gap. Gaps are for thicker mat...   Jan 3 2007, 06:19 AM
faux916   One should always practice welding on the wifes ca...   Jan 3 2007, 08:22 AM
spunone   If ya can't see for shit when welding ya might...   Jan 3 2007, 02:37 PM
Lawrence   Looks good, dude. Come borrow my welding helmet, ...   Jan 3 2007, 03:03 PM
Lawrence   And by good... I mean for a first try. You may NO...   Jan 3 2007, 03:08 PM
cooltimes   I agree with Rusty. Not bad for a 1st time adventu...   Jan 3 2007, 03:22 PM
SGB   WOW. Great site, Mike. Thanky much.   Jan 4 2007, 08:16 AM
- Lo-Fi Version Time is now: 31st October 2024 - 07:28 PM
