Look y'all, I done welded iyut., My first try... |
SGB |
Jan 2 2007, 05:41 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
OK. It looks AWFUL. JUST AWFUL. But thes pieces are really and fully attached. Even actually fused like real welding in a few spots. I'm gonna keep practicing a little before I attempt car stuff, I think. (IMG:style_emoticons/default/smile.gif)
For a cheapie HF wire feed (not mig), it seems to work OK. Who has some good welding tips? I saw something on the almighty internet that indicated there might be primer of some kind? When do ya use this? What do I need to look out for? It's kinda fun. The biggest challenge is starting "in the dark". How easy is it to burn 914 sheet metal up? This is only a two setting unit- high or low. So far I've been using just low. So here is my sculpture. Now I really need a good cut-off tool.... Attached thumbnail(s) |
alpha434 |
Jan 2 2007, 09:44 PM
My member number is no coincidence. Group: Members Posts: 3,154 Joined: 16-December 05 From: Denver, CO Member No.: 5,280 Region Association: Rocky Mountains |
Get a welding book.
It helps to pre-heat the work piece. Try it in your oven. 350 deg or so. That'll help. Flux core will help too. But a purge gas is still best. When you get into the high-end stuff (like your car.) They've proven that sunlight helps in some way. EDIT:And take lots of time with the prep work. Make sure everything is very clean. Use a metal-prep solution after wirebrushing it clean. And DON'T get a crappy auto-darkening helmet from Harbor Freight. They suck. They are POS. They're response time is really poor, so you get bad burn-in after a few time off-on.When it comes to your eyesight, get the best. Get oone with a faster response time, or get a traditional helmet (because it'll ALWAYS be on when you're using the torch.) |
McMark |
Jan 3 2007, 12:38 AM
And DON'T get a crappy auto-darkening helmet from Harbor Freight. They suck. They are POS. They're response time is really poor, so you get bad burn-in after a few time off-on.When it comes to your eyesight, get the best. Get oone with a faster response time, or get a traditional helmet (because it'll ALWAYS be on when you're using the torch.) I used one for a long time and I still have it for my backup helmet. I never experienced any issues with it other than the head strap breaking. I never got any burn-in, and I used it A LOT! For a hobby welder, I think it's perfect. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:32 PM |
