> Question about putting car up on jack stands, et. al.
Cevan
post Jan 4 2007, 02:41 PM
That's my car in the avatar. It hasn't been run in 2-3 years, according to the PO. I'm hoping to get it running this weekend and confirm that the engine, tranny, brakes, electrical, etc work sufficiently. Assuming I can make the car go forwards and backwards and at least slow it down, I want to start repairing the rust.
I have a few questions I'm hoping someone can help me with:
1. Where is the best place to put 4 jack stands in order to do this work?
2. Should I put the doors back on the car in order to be able to see if the car is sagging once I start cutting? Is there some other/additional measures I should take? Some of the inner rock needs to be replaced. The inner logitudinal looks good on both sides.
3. There are two black plastic flaps connected to the rear end of the floor pan. I want to remove them in order to clean/check for rust. They appear to be attached with plastic bolts, but the heads are round with no slot. How do I remove them?
4. I have the interior removed. Do I need to remove the sound deadening tar paper in the floor pan? 95% of the floor pan looks sound.
5. From the inside, the area behind the seat pad is rust-free. Should I remove the firewall blanket inside the engine compartment? I realize some may have to be pulled away to get at the hellhole. I'm afraid I'll breakoff those metal strips that hold it on once I lift them up.
6. Some of the inner rocker is rusted through and some is solid. Should I cut out and replace the whole thing? Is it better to be able to check out the heater tubes and clean around in there?
I'll post some pictures tonight. I'm just not sure where to start. I'm afraid of cutting too much and messing up alignment of the body. Thanks.
Eric_Shea
post Jan 4 2007, 05:03 PM
PMB Performance
(fixed the above post)
Not sure what you mean?
What are jackstands? (IMG:style_emoticons/default/av-943.gif)
dr914@autoatlanta.com
post Jan 4 2007, 05:16 PM
QUOTE(Eric_Shea @ Jan 4 2007, 03:03 PM) *
This guy is a funny man!
- Lo-Fi Version Time is now: 26th November 2024 - 12:18 PM
