Question about putting car up on jack stands, et. al. |
Cevan |
Jan 4 2007, 02:41 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
That's my car in the avatar. It hasn't been run in 2-3 years, according to the PO. I'm hoping to get it running this weekend and confirm that the engine, tranny, brakes, electrical, etc work sufficiently. Assuming I can make the car go forwards and backwards and at least slow it down, I want to start repairing the rust.
I have a few questions I'm hoping someone can help me with: 1. Where is the best place to put 4 jack stands in order to do this work? 2. Should I put the doors back on the car in order to be able to see if the car is sagging once I start cutting? Is there some other/additional measures I should take? Some of the inner rock needs to be replaced. The inner logitudinal looks good on both sides. 3. There are two black plastic flaps connected to the rear end of the floor pan. I want to remove them in order to clean/check for rust. They appear to be attached with plastic bolts, but the heads are round with no slot. How do I remove them? 4. I have the interior removed. Do I need to remove the sound deadening tar paper in the floor pan? 95% of the floor pan looks sound. 5. From the inside, the area behind the seat pad is rust-free. Should I remove the firewall blanket inside the engine compartment? I realize some may have to be pulled away to get at the hellhole. I'm afraid I'll breakoff those metal strips that hold it on once I lift them up. 6. Some of the inner rocker is rusted through and some is solid. Should I cut out and replace the whole thing? Is it better to be able to check out the heater tubes and clean around in there? I'll post some pictures tonight. I'm just not sure where to start. I'm afraid of cutting too much and messing up alignment of the body. Thanks. |
Eric_Shea |
Jan 4 2007, 05:03 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
(fixed the above post)
Not sure what you mean? What are jackstands? (IMG:style_emoticons/default/av-943.gif) |
ClayPerrine |
Jan 4 2007, 06:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,906 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
(fixed the above post) Not sure what you mean? What are jackstands? (IMG:style_emoticons/default/av-943.gif) Yea.. what the hell are jackstands?? OH.. you mean 914 Feet..... Ya gotta be careful with those... they grow out of the bottom of 914s when they are parked in one place too long. When you finally try to drive it, they have to be amputated so the wheels will touch the ground again..... (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 26th November 2024 - 12:24 PM |
