> GT metal flares- how to install?
rfuerst911sc
post Jan 6 2007, 03:27 PM
Well I signed up for the group buy of GT metal flares so now I want to know how to install these. I have a mig welder and am a fair welder so my intention is to install these myself. Once you cut the fenders ( hopefully correctly ) you line the flares up and tack them in place right? Once tacked do you run a continous bead or do you do spaced welds? Once tacked/welded then you grind the welds flush? And then do your skim coats of bondo to finish? Any online forum how to's on this? I know that the least amount of heat is good to keep warping to a minimum but any tips are appreciated. Thanks (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations
post Jan 6 2007, 06:15 PM
I. I. R. C.
I don't have a pic of the actual cutting, but I use an air powered body saw, that's like a jigsaw. I barely cut the edge of the flair and the underlying fender at the same time, so you have a perfect seam. Then I clamp the two pieces, as I cut, with some panel clamps for butt welding panels together, and tack weld the flair on to the fender following the cut line.
rfuerst911sc   GT metal flares- how to install?   Jan 6 2007, 03:27 PM
dr914@autoatlanta.com   Well I signed up for the group buy of GT metal fl...   Jan 6 2007, 03:45 PM
9146986   What i do is carefully positon the flair in the co...   Jan 6 2007, 06:04 PM
9146986   And like this   Jan 6 2007, 06:06 PM
9146986   I don't have a pic of the actual cutting, but ...   Jan 6 2007, 06:15 PM
9146986   Here's what it looks like after it's cut a...   Jan 6 2007, 06:18 PM
9146986   I didn't take a pic of the top side of the fla...   Jan 6 2007, 06:28 PM
9146986   After it's all welded up nice and solid I care...   Jan 6 2007, 06:37 PM
9146986   I've never installed an AA set, but the factor...   Jan 6 2007, 06:43 PM
9146986   Here's the bottom of the flair after some work...   Jan 6 2007, 06:45 PM
9146986   And when it's all done it will look just like ...   Jan 6 2007, 06:49 PM
rfuerst911sc   The pics are great. For some reason I thought the ...   Jan 6 2007, 07:54 PM
9146986   The pics are great. For some reason I thought the...   Jan 7 2007, 12:22 AM
ptravnic   Perry - If you don't mind me asking, what (bal...   Jan 6 2007, 08:05 PM
dgw   Perry - If you don't mind me asking, what (ba...   Jan 7 2007, 01:02 PM
will   Perry - If you don't mind me asking, what (b...   Jan 7 2007, 01:24 PM
Travis Neff   This thread should be in the classics   Jan 6 2007, 08:50 PM
Hoss   This thread should be in the classics I complet...   Jan 7 2007, 12:54 AM
seanery   Great Question! AWESOME Response!! :...   Jan 7 2007, 09:25 AM
9146986   Thanks guys! I had planned to take step by st...   Jan 7 2007, 09:52 AM
Hoss   Thanks guys! I had planned to take step by s...   Jan 7 2007, 11:39 AM
cooltimes   I hope this post relates to the subject. If not, I...   Jan 7 2007, 10:47 AM
echocanyons   Classic!   Jan 7 2007, 11:53 AM
STL914   Here's a link to a thread following the progre...   Jan 7 2007, 04:04 PM
scotty b   For you guys looking for a price, I obviously can...   Jan 7 2007, 04:30 PM
dgw   B)-->
- Lo-Fi Version Time is now: 28th April 2025 - 03:35 PM
