The Official 914 World 3 Rotor 914 Build Thread, Otherwise known as round and round we go...... |
soloracer |
Jan 6 2007, 11:37 PM
Senior Member Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 |
Well there has finally been some progress made on my car so I thought I would start a build thread about it for those who are interested. I'll try to keep it updated as I go along.
I'll start off with an introduction to the project for those who don't already know. I bought a 914 with a Sheridan Motorsports wide body in an E-bay auction. The car was being set up for a Porsche 6 to be used on the track. It came with the wide body, a 915 transmission (mag case) that was converted to side shifter with a Vellios kit and the ring and pinion had been flipped. The front suspension is supposed to be from a 911 - don't know the year yet - and the car has a brand new set of Kinesis rims that appear to be 17x12 in the back and 17x10 in the front. Also included were a set of new tires 315's in the back and 285's in the front. The previous owner also had put a front mount oil cooler and a somewhat poorly welded roll cage. Here are some pictures of the car: Attached image(s) |
soloracer |
Jan 7 2007, 12:24 AM
When Paul went to install the engine he found that it was going to be too long so I bought the Renegade Hybrids transmission blocks that you V8 guys use to shift everything back a few inches. I also purchased 4 WEVO semi solid engine and transmission mounts. Since the transmission was converted to side shifter I found an engine mount bar for side shifter on e-bay and purchased it.
Paul proceeded with getting the engine mocked up and this is where we are today. He found that he still had to make a cut in the firewall for the water pump and it looks like the firewall will have to be reshaped around the top of the water pump where the thermostat is to give adequate clearance Attached thumbnail(s) |
Lo-Fi Version | Time is now: 7th January 2025 - 11:33 AM |
