> The Official 914 World 3 Rotor 914 Build Thread, Otherwise known as round and round we go......
soloracer
post Jan 6 2007, 11:37 PM
Well there has finally been some progress made on my car so I thought I would start a build thread about it for those who are interested. I'll try to keep it updated as I go along.
I'll start off with an introduction to the project for those who don't already know. I bought a 914 with a Sheridan Motorsports wide body in an E-bay auction. The car was being set up for a Porsche 6 to be used on the track. It came with the wide body, a 915 transmission (mag case) that was converted to side shifter with a Vellios kit and the ring and pinion had been flipped. The front suspension is supposed to be from a 911 - don't know the year yet - and the car has a brand new set of Kinesis rims that appear to be 17x12 in the back and 17x10 in the front. Also included were a set of new tires 315's in the back and 285's in the front. The previous owner also had put a front mount oil cooler and a somewhat poorly welded roll cage.
Here are some pictures of the car:
soloracer
post Jan 7 2007, 12:30 AM
The plan is to build brackets that will bolt the engine to the bar which is in turn mounted to the chassis with the WEVO semi solid motor mounts. The plan is to use the three bolts holes above the bar (triangular - the bolt is in the bottom left part of the triangle). We will consult with Max to get his thoughts on this as he is the expert on the engine. Originally Max had wanted to build a baffle plate that had ears that we could mount to. He has worked in performance shops in Japan and said that the baffle plate would be strong and be a good place to mount to if the plate was made thick enough. However, Paul believes these existing bolt holes are good enough.
soloracer   The Official 914 World 3 Rotor 914 Build Thread   Jan 6 2007, 11:37 PM
soloracer   For a number of years the car has sat in my garage...   Jan 6 2007, 11:54 PM
soloracer   In my garage the engine, transmission and car sat ...   Jan 6 2007, 11:58 PM
soloracer   One day at one of our Porsche Club track events a ...   Jan 7 2007, 12:07 AM
soloracer   I went to Kennedy Engineering ( http://www.kennedy...   Jan 7 2007, 12:12 AM
soloracer   While trying to figure out how to accomodate inter...   Jan 7 2007, 12:18 AM
soloracer   When Paul went to install the engine he found that...   Jan 7 2007, 12:24 AM
soloracer   The plan is to build brackets that will bolt the e...   Jan 7 2007, 12:30 AM
soloracer   Paul also removed the front oil cooler that the pr...   Jan 7 2007, 12:34 AM
soloracer   This is where we are at today. Paul is also going...   Jan 7 2007, 12:40 AM
drive-ability   This is where we are at today. Paul is also goin...   Jan 7 2007, 01:10 AM
Dr. Roger   This is where we are at today. Paul is also goin...   Jan 7 2007, 05:56 PM
soloracer   This is where we are at today. Paul is also goi...   Mar 10 2007, 12:05 AM
John   This is where we are at today. Paul is also goin...   Mar 8 2007, 10:29 PM
John   This is where we are at today. Paul is also goin...   Mar 10 2007, 12:53 AM
soloracer   Here is another interesting shot showing the chass...   Jan 7 2007, 12:41 AM
soloracer   The car didn't have a steering wheel when I go...   Jan 7 2007, 12:44 AM
soloracer   I also ordered and received my independant throttl...   Jan 7 2007, 12:47 AM
soloracer   Here is a picture of what I expect the car to look...   Jan 7 2007, 12:50 AM
soloracer   Here are three peripheral ported rotary housings c...   Jan 7 2007, 01:04 AM
soloracer   Thanks! The axles do have two dowels and 4 bo...   Jan 7 2007, 01:20 AM
soloracer   I picked up a 915 transmission cooler on E-Bay for...   Jan 7 2007, 04:17 PM
Mueller   that plastic V8 is pretty darn cool..... how much...   Jan 7 2007, 05:11 PM
soloracer   Mueller: I don't know how much the bare 20b e...   Jan 7 2007, 07:22 PM
ArtechnikA   One thing that was brought up was that the oil co...   Feb 4 2007, 06:48 PM
smrz914   My rear breaks look really similar but i still hav...   Jan 9 2007, 12:34 AM
soloracer   I found 4 peripheral port 20b videos on youtube. ...   Jan 16 2007, 12:48 PM
turbo914v8   Before you put the 20B back together you should in...   Jan 19 2007, 11:26 PM
soloracer   Before you put the 20B back together you should i...   Feb 4 2007, 01:06 AM
djfamousa   Yep, I would have to agree. My last car was a 3...   Mar 2 2007, 10:26 PM
soloracer   On another note I am told that the engine mount is...   Feb 4 2007, 01:08 AM
Rotary'14   Just found your thread! I was on anoter site...   Feb 4 2007, 06:45 PM
soloracer   ArtechniKa: I have come to the same realization. ...   Feb 4 2007, 07:06 PM
Heeltoe914   ArtechniKa: I have come to the same realization....   Feb 5 2007, 11:23 AM
Rotary'14   ArtechniKa: I have come to the same realization...   Feb 5 2007, 12:10 PM
soloracer   [quote name='Heeltoe914' post='858989' date='Feb ...   Feb 6 2007, 11:13 PM
ArtechnikA   For those curious about the 915/67 Euro trans cool...   Feb 6 2007, 07:03 AM
army dude   First off... You go!!! I will be watch...   Feb 6 2007, 07:44 AM
soloracer   Ian: Thanks for the nice response. :) The engi...   Feb 6 2007, 11:10 PM
soloracer   Just a little update here. The engine mount is do...   Feb 26 2007, 01:42 AM
Rotary'14   Engine mount looks sweet! :Qarl: Keep the ...   Feb 26 2007, 05:30 PM
soloracer   Just a quick update. The engine will be going to ...   Mar 8 2007, 12:43 AM
db9146   I had a chance to ride in a 914 powered by a stock...   Mar 8 2007, 10:10 PM
John   Um, that isn't all the parts for the 915 pump/...   Mar 8 2007, 10:17 PM
soloracer   Thanks! I didn't know that. It makes se...   Mar 10 2007, 12:00 AM
John   You need to measure the cv joints on the 911 axles...   Mar 10 2007, 12:46 AM
soloracer   Thanks for the identification. That resolves a fe...   Mar 15 2007, 12:36 AM
soloracer   Just an update: I'm still in the search for a...   May 11 2007, 04:43 PM
soloracer   I just read on another forum where they weighed th...   May 12 2007, 08:49 PM
38 User(s) are reading this topic (38 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 11:46 AM
