Scott-thundercat |
Member ![]() ![]() Group: Members Posts: 159 Joined: 16-October 06 From: Reno, NV Member No.: 7,049 ![]() |
Okay so i've run the gammit of crap for this car. new cap, new rotor, new points, new condensor, new plug wires, new coil, adjusted valves, replaced BENZ fuel pump with late 914 fuel pump (thinking maybe too much pressure was problem). replaced all fuel hoses, replaced fuel tank (no kinks in lines), replaced fuel filter.
questions are thus- when i start the car it runs, it runs rough but it still runs. let it warm up- can drive it while cold- when it warms up it dies and wont restart for quite some time. plugs dont have oil on them but do have some signs of way too much fuel. this sounds like it could be the CHT sensor. Question- i have a black wire coming off of what looks like the CHT sensor slightly in front of the rear cylinder on the passenger side's spark plug... doesnt connect to anything- dont see where it could connect to... where does this wire usually live? also going to bypass the Cold start injector cause i think it might be leaking into the engine fueling the oil. the engine runs quite rough (like at least one cylinder is missfiring)- until i let off the throttle from around 3K rpm- then it runs perfectly (but at 2000 RPM) for a few seconds before becoming rough and crappy again- why? this car is slowly killing me- i've found so many problems and fixed em only to have more left. i'm going to head down to go work on it-(parked at a gas station where i limped it to while trying to drive to my new apartment). if anyone has some great advice or wishes to help please call me at five three zero 220 four zero 33... sorry for the wierd way of writing it- dont want any autoscanners to pick it up. Scott |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
QUOTE The CHT sensor should plug into a wire in the main EFI wiring harness that comes out of the "brain". Look for a single wire that comes out of the harness near where the four wires for the MPS come out of it, and where the four wires for the two right-side injectors come out. Bowlsby has a better idea of the exact places where those things branch off of the main harness, but it's in that area... This is your first problem! You cant get any further until you fix the CHT. That wire needs to be hooked up for the car to adjust the fuel/air mixture when it warms up. I bought a car from a guy who put a new motor in and never could figure out why it wouldn't run when warm. He put a new harness, brain, fuel/air valve and then gave up and sold me the car to me for $1700. I found that the CHT had stripped threads so it tested ok but sent out in-acurate signals to the computer. Jeff |
Lo-Fi Version | Time is now: 26th June 2024 - 03:56 AM |
