brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
I have seen the twin spark dizzies. Straight forward.
Then there are the crank fire twin pack setups. ok. what else can be used? Piggyback systems? (picture is for entertainment purposes only. this is not my motor) Attached image(s) ![]() |
DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
You could use EDIS to trigger COP but, it's not as easy as it seems on the surface.
At first is would seem that a module for a 8 cylinder car on a 4 cylinder engine might give 4 cylinder twin plug but, it won't work because the sparks are miss timed. It will fire 8 times in 720 crankshaft degrees (1 engine cycle). This means it fires near TDC (good) but also near BDC (bad). So then, how about two 4 cylinder modules? Here are some things to consider. Each module must have a signal from a VR sensor or the module will revert to limp home mode (constant 10 degrees advance). If one uses 2 separate VR sensors so each module has it's own VR sensor there will be a difference in timing because it's impossible to mount them on top of each other. So, that means the 2 modules must share the VR sensor. Fortunately, this will work, I've done it on the bench with the trigger wheel on my drill press. One can use the tach imput signal (PIP) from one module to trigger the ECU. This is known to work cause it is exactly how I trigger my engine now. The timing advance signal from the ECU (SAW) can be split and go to both modules. This is known to work. Thankfully, the modules do dwell control themselves. So at this point there would be a current from 2 modules that could charge the primaries of 2 coils and the dwell is taken care of kind of. Here's the deal, each EDIS coil has 2 poles and each is attached via the spark plug wire to a plug. The current runs from 1 pole through the wire to the plug with a strong spark in the fuel and air, then through the engine to the other plug where it sparks and returns to the other pole of the same coil. The second spark is weak because it has to spark through exhaust gas. This second plug also has a reversed polarity. Almost all of the energy from the coil sparks in the first cylinder. If you try to spark both through air/fuel as in twin plug situation you get 2 sparks with about half the energy of a normal application. I really don't think this so hot. I know this is not COP but, I'm getting there. The solution to this is to run the wires from tower 1 of the first coil to cylinder 1 and the tower 2 to cylinder 3 and repeat with the second coil. In essence, this is separate EDIS systems running in parallel but sharing imputs. Now here's the problems with COP and EDIS. The coil drivers in the EDIS modules expect coils of a certain inductance. If that value isn't close the dwell will be wrong and the coils will either heat up too much or have a weak spark. I don't know what inductance EDIS expects and this info is not easy to find for most coils. If it could be matched it would probably work but, it would still be wasted spark and each set of plugs would fire twice in an engine cycle and that halves one of the advantages of COP which is long coil dwell. It is certainly a compromise. The really solution as I see it should take 1 of 2 paths. First, there are COP coils that are smart meaning they contain the driver and dwell control in the coil case on the plug. These then only need a signal from the ECU to chargeprimary and discharge collapsing the field. These probably would get a 5 Volt signal from the ECU. It's been a while since I looked but, I believe some GM coils are smart. To do this right, the ECU would need information on crank position for timing and information on cam position to know which cylinder to fire. Likely the ECU would need 4 ignition outputs and the 2 coils on each cylinder could share the same 5 V signal. The second way to do it would involve conventional coils. In this case the coil drivers and dwell control are in a module or in the ECU. The sensors required would be the same as above but, one would need 8 ignition outputs that would carry 12 Volts and enough amperage to charge the primaries of the coils. The advantage of this is it is more widely applicable and the coils are a lot cheaper. Likely, the dwell would need to be tuned in the software. To me this just seems like too much work. I just can't see that I would gain much over the EDIS system I am running now. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 29th June 2024 - 04:10 AM |
