KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I posted this on Narp during the "Great Divide." I am now getting ready to start this project so I figured I'd post here, with the additional suggestions from the folks on Narp.
I picked up a 1911 motor from Grimstead a few weeks ago. I will be replacing my stock 1.7 with the 1911. I also have a set of 44 idfs for that motor too. So while I am going to swap this motor, I figured I'd check to see what else I should do "while I am in there?" If anyone knows the ball park costs for some of these items, please list it too, as it will help me budget. I don't want Dirk Wright disease, but I want to take care of any maintenance items while I have the old motor out and am prepping for the new one. clutch fuel lines tranny mounts new fuel pump - CB Rotary $60 various jets, and venturis for tuning the carbs - based upon recommendations (32 chokes) cv gaskets red loctite (something I need to get for all of this) trans mainshaft seal and cup bushing in the TOB arm... new bolts for the flywheel if you have it off A type 1 oil pump that has already had the shaft milled is a great investment if you want to upgrade your oil system & seals. Check the CV joints and repack them. Rebuilt alternator (I have a new starter) Check that right rear suspension point where the trailing arm pivots. Thats below the battery tray and corrodes from the inside out. $?? do andy's jumper wire at the engine relay board to power the pump. Help me out fellas! Thanks, Joe |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
QUOTE red loctite (something I need to get for all of this) Be careful with red loctite. It's the more permanent type. Blue or purple is the lesser strength color. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:06 AM |
