brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
I have seen the twin spark dizzies. Straight forward.
Then there are the crank fire twin pack setups. ok. what else can be used? Piggyback systems? (picture is for entertainment purposes only. this is not my motor) Attached image(s) ![]() |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
brer, I think I found a solution for firing the twin-plugs via a distributor...
Compufire has a kit that has some electronic that go into your distributor which in turn fire a twin coil pack (wasted spark) I would almost be willing to bet that if you connected up another coil pack, the control modual that resides inside the distributor would also be able to fire the second set up plugs. so for less than $300 (according to ebay) you would have all that is needed to fire all 8 plugs.... I'd also bet that you could fit the parts needed into a Mallory body so that you could easily set your advance curve if you wish. ![]() compufire dis-x |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
brer, I think I found a solution for firing the twin-plugs via a distributor... Compufire has a kit that has some electronic that go into your distributor which in turn fire a twin coil pack (wasted spark) I would almost be willing to bet that if you connected up another coil pack, the control modual that resides inside the distributor would also be able to fire the second set up plugs. so for less than $300 (according to ebay) you would have all that is needed to fire all 8 plugs.... I'd also bet that you could fit the parts needed into a Mallory body so that you could easily set your advance curve if you wish. ![]() compufire dis-x that gives you a crappy 009 advance curve |
Lo-Fi Version | Time is now: 29th June 2024 - 05:01 AM |
