jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
Need a little help here. I did a quick test fit of a used harness bar I won on ebay. It came off another 914.
As the pic shows, I am struggling getting it to fit with the existing seat belt bracket. As you can see, because of the mounting plate of the bar, the existing seat belt bracket sits at an odd angle (it should hang straight down). The original belt is still usable at this angle, but it does make it bind somewhat. Am I missing something or is this just how it is? My idea was to keep the bar mounted in the car permentally, but of course use the standard belts for day to day driving. I appreciate any tips, thanks! Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
they are NOT designed to work with stock belts.....
for the 5 points... not for the stock inertia reels.. you get used to 4 points in a daily driver... it isnt bad. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
they are NOT designed to work with stock belts..... for the 5 points... not for the stock inertia reels.. you get used to 4 points in a daily driver... it isnt bad. Bull (IMG:style_emoticons/default/stromberg.gif) We have stock belts in both cars AND the harness bar. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:19 PM |
