VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I like my big black bumpers, but I don't like how heavy they are.
I was thinking that I could make a fiberglass mold out of the steel insert, and then fill that with some high density foam, like modern bumpers. Put it back in the rubber insert, and call it a day. Problem is, I don't know the first thing about laying up fiberglass. Help? Zach |
highways |
Senior Member ![]() ![]() ![]() Group: Members Posts: 613 Joined: 18-June 05 From: Los Angeles, CA Member No.: 4,296 ![]() |
Having worked as a composite technician in aerospace as well as doing boat repair and composite model sailplane building... I just have to say that
:fiberglass : + :can of worms: + (IMG:style_emoticons/default/stromberg.gif) + :tar and feathered: + (IMG:style_emoticons/default/stfu.gif) = :project failure accompanied by record levels of self loathing: Actually- there are easy ways and hard ways to do things. And there are lots of decent ideas being thrown out here. Just need some pictures, a plan, and some material test experiments to know what you're getting into. I personally would probably start going about it as okieflyr suggested below. Carve a blank (I like hot wires), sort of 'cut and paste' to shape, add filler to shape even better, then glue into bumper. I would only worry about the density of the foam as far as 'ease of shaping' goes. But when it comes to finished rigidity you can always wrap it in some 4 ounce clothe. Real bumper foam is EPP or Polystyrene- and is very soft. This could be a 4 hour project as opposed to a 3 week mold making project. Another, maybe simpler approach would be to make a high density foam log, and carve it to fit it the same space as the steel beam. The higher the density, the more weight. The foam can be worked like a light wood with saws,sanders, and sureforms.. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:52 PM |
