> Its the final countdown, progress thread
type11969
post Jan 8 2007, 09:29 PM
I've had this 71 for 3 years now and I've only driven it for 10 minutes before I bought it. I figure if I haven't made serious progress by the spring, she is getting stripped and scrapped. You'll see why. Its probably only a parts car, but I want to learn how to weld, and if I can get this thing back on the road, I think I will be well on my way. I'll start from the beginning:
The exterior, looks harmless enough:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/914.jpg)
The interior, looks pretty good (wait, what was that saying about wrapping a piece of poo in a pretty package):
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/914012.jpg)
Long looks okay at first glance:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/914009.jpg)
Wait, umm, is this factory installed golf ball sized hunks of epoxy and bondo:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404015.jpg)
Yum:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404010.jpg)
Delicious:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404012.jpg)
Craptacular:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/914-2018.jpg)
Brace yourself (also have another brace running to the drivers side door jamb, couldn't find that pic):
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404001.jpg)
Couldn't find any pics of the lovely riveting and brazing job a PO did with re-attaching the portion of the fender below the sail, but I hacked that focker off:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/121304002.jpg)
Mmm, clean:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/121304013.jpg)
Also found after removing the interior that the passenger side was once used as a pool, the entire lower inner corner of the long and bulkhead was gone. PO crappily arc welded a new floorpan in, but didn't fix any of the other damage:
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture069.jpg)
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture070.jpg)
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/Picture071.jpg)
(IMG:http://i19.photobucket.com/albums/b188/type11969/914/111404002.jpg)
Quick break, then pics of the repairs so far . . .
dr914@autoatlanta.com
post Jan 30 2007, 09:01 AM
my only two comments here are:
1 What a hero to save this 914!
2 Why hours and hours and hours and hours and hours of patching when aftermarket panels are readily available, cheap would have saved hours and hours of hard labor, kept the car more factory original, made it stronger, more valuable, and made it last much much longer?
type11969
post Jan 30 2007, 11:51 AM
Car is a parts car, I reviewed your website, and to buy the panels needed I would be way over the purchase price of the car. Simply not worth it in my book. Plus I only would have needed sections of parts you have available. You aren't talking about complicated parts here either, fabbing isn't that difficult, moreover, I find it enjoyable and a good stress reliever.
From the outside, the repairs I have made will be pretty damn close to factory original. And I know my repairs are as strong as original since they are modeled after what was there originally. Question for you, are your repair panels thickened in areas where Porsche had mulitple layers (like in the long and many other places in the "frame")? Or are they simply the mulitple layer thickness throughout? From the pics it seems like they are only single layer, so either they are too thin (compared to original) or too heavy (again, using original as the benchmark).
More valueable? Again, if it looks stock from the outside . . .
Last much longer? Ummm, you have somehow sourced a grade of steel better than mine? I don't remember posting the material specs of what I was using anywhere . . . (IMG:style_emoticons/default/rolleyes.gif)
QUOTE(dr914@autoatlanta.com @ Jan 30 2007, 07:01 AM) *
post Jan 30 2007, 01:46 PM
QUOTE(type11969 @ Jan 30 2007, 09:51 AM) *
I did not want to upset you at all. That was not my intent and again I am happy that you are saving a 914. (by the way that was NOT a parts car)
The aftermarket panels that several manufacturers make are actually thicker than the original steel and where Porsche reinforced them they have been reinforeced as well or make of double thickness to aid in the manufacture. Rest assured that the guys who make these panels are well familier with the 914 and would not cheat by making an inferiour panel!!!!! that alone would be real STUPID when it takes so little to get it right. We often use their panels here and cut them just using what we want, as it saves loads of time for the effort to fabricate (and believe me we know!!!!)
bottom line here Chris? If your time is free go for it of course and the time spent on one's 914 does lower the blood pressure, sort of like petting your dog, but the car is much better off in the long run being repaired as close to how the factory manufactured it, it actually takes less time and less money if your labor is not free, and when you finally die at 115 and someone is selling your 914, the buyer will not say, "Wow, I sure wish this 914 had been repaired properly as I would have paid 20,000 more for it!" and then your great great grandson laments that his legacy from you has been compromised.!!! Fix it right fix it once, but by all means fix a 914!
type11969
post Jan 30 2007, 02:20 PM
QUOTE(dr914@autoatlanta.com @ Jan 30 2007, 11:46 AM) *
Okay, my bottom line is I don't think I need to use the repair panels you sell to repair my car properly. I can see why you may think otherwise . . .
post Jan 30 2007, 02:38 PM
QUOTE(type11969 @ Jan 30 2007, 12:20 PM) *
And Chris I completely defer to the man who has put that much time into his 914 and congratulate you.
dkos
post Jan 30 2007, 03:36 PM
say, "RUST"!
Dr.,
It's a rare talent you have. It's not easy to offend someone with a compliment. You are a master.
I'm assuming it's not your intent, but somehow it comes across that way. I guess that's one of the dangers of "talking" this way. You can't hear the other person's tone of voice or see their eyes rolling.
Dave
type11969   Its the final countdown   Jan 8 2007, 09:29 PM
type11969   Pics too big? I'll resize if needed. Repairs ...   Jan 8 2007, 09:37 PM
type11969   Last for the night . . . 914 and garage on the mov...   Jan 8 2007, 09:40 PM
Hammy   Don't scrap. Why give up after you've gone...   Jan 8 2007, 10:39 PM
markb   Don't scrap. Why give up after you've gon...   Jan 8 2007, 11:37 PM
Eric Taylor   yeah man! Awesome work. I really admire people...   Jan 8 2007, 10:48 PM
McMark   Scrap? Give up? Did I miss something? :blink: He...   Jan 9 2007, 12:07 AM
JerryP   Nice work Chris. Where are you in Philly? I have a...   Jan 9 2007, 07:24 AM
type11969   Not really a reference to arrested development, bu...   Jan 9 2007, 07:32 AM
type11969   Jerry- I'm in Northern Liberties, about 1-1.5...   Jan 9 2007, 07:36 AM
type11969   Mark, missed the youtube movie you posted until no...   Jan 9 2007, 07:38 AM
type11969   tacked http://i19.photobucket.com/albums/b188/typ...   Jan 10 2007, 07:54 PM
McMark   Looking good! :thumbsup: Watch out for warpa...   Jan 10 2007, 10:50 PM
type11969   Looking good! :thumbsup: Watch out for warp...   Jan 11 2007, 07:05 AM
tdsmoonchild   Yeah, I'm jumping around from one location on...   Jan 12 2007, 09:39 AM
Boojum   Yeah, I'm jumping around from one location o...   Jan 30 2007, 02:56 PM
swood   thanks burger boy...I'm going to have that dam...   Jan 10 2007, 10:58 PM
highways   I was doing 1 inch welds on front fender filling i...   Jan 12 2007, 05:35 PM
type11969   Sadly the weekend was mostly a waste, got a little...   Jan 16 2007, 09:56 PM
nebreitling   jesus! that is an insane project. congratulat...   Jan 16 2007, 10:05 PM
type11969   Thanks! I wish I was putting all this effort i...   Jan 17 2007, 06:55 AM
type11969   Things weren't going my way today. Welds kind ...   Jan 17 2007, 09:52 PM
McMark   That's lookin' really nice.   Jan 17 2007, 10:10 PM
r_towle   I love what you have done there, looks nice and so...   Jan 17 2007, 10:14 PM
Hammy   Lookin good..... keep it up   Jan 17 2007, 10:26 PM
type11969   Thanks for the kudos, hopefully it is as strong as...   Jan 18 2007, 07:11 AM
dkos   Thanks for the kudos, hopefully it is as strong a...   Jan 27 2007, 11:30 AM
dkos   Here are some pics of the Brad Mayuers piece. Top ...   Jan 27 2007, 11:33 AM
type11969   Got a little done this weekend. Ground some welds ...   Jan 22 2007, 08:05 AM
rick 918-S   Lookin good! <<<<<------- :sha...   Jan 22 2007, 08:34 AM
autohausdolby   Some serious work there!   Jan 24 2007, 08:29 AM
type11969   Some more progress, piece fabbed: http://i19.phot...   Jan 24 2007, 09:40 PM
dkos   how it attaches   Jan 27 2007, 11:59 AM
SGB   GO! GO! wow. build-it-yerself car. Nea...   Jan 27 2007, 02:14 PM
type11969   Thanks Scott! Dave, your long looked pretty g...   Jan 29 2007, 09:37 PM
dkos   Chris, The reinforcement piece welds in along the...   Jan 30 2007, 08:27 AM
dkos   My car was in similar condition to yours.   Jan 30 2007, 08:29 AM
dkos   I ended up cutting away all that rust and recreati...   Jan 30 2007, 08:51 AM
type11969   I ended up cutting away all that rust and recreat...   Jan 30 2007, 11:22 AM
dkos   I ended up cutting away all that rust and recrea...   Jan 30 2007, 11:30 AM
dr914@autoatlanta.com   my only two comments here are: 1 What a hero to ...   Jan 30 2007, 09:01 AM
dkos   my only two comments here are: 1 What a hero to...   Jan 30 2007, 09:22 AM
type11969   Car is a parts car, I reviewed your website, and t...   Jan 30 2007, 11:51 AM
dr914@autoatlanta.com   Car is a parts car, I reviewed your website, and ...   Jan 30 2007, 01:46 PM
type11969   [quote name='type11969' post='856147' date='Jan 3...   Jan 30 2007, 02:20 PM
dr914@autoatlanta.com   [quote name='type11969' post='856147' date='Jan ...   Jan 30 2007, 02:38 PM
dkos   Dr., It's a rare talent you have. It's no...   Jan 30 2007, 03:36 PM
dr914@autoatlanta.com   "And Chris I completely defer to the man who...   Jan 30 2007, 03:47 PM
dkos   well said!   Jan 30 2007, 03:51 PM
SGB   well, y'know, sometimes we got time, sometimes...   Jan 30 2007, 09:13 AM
dkos   My intitial plan was to also fabricate the inner r...   Jan 30 2007, 09:19 AM
dr914@autoatlanta.com   My intitial plan was to also fabricate the inner ...   Jan 30 2007, 09:24 AM
dkos   My intitial plan was to also fabricate the inner...   Jan 30 2007, 09:36 AM
dr914@autoatlanta.com   [quote name='dr914@autoatlanta.com' post='856081'...   Jan 30 2007, 09:53 AM
type11969   Fortunately my driver's side seems sound right...   Jan 30 2007, 11:37 AM
dkos   Fortunately my driver's side seems sound righ...   Jan 30 2007, 11:45 AM
dkos   some pics   Jan 30 2007, 11:40 AM
dkos   more:   Jan 30 2007, 11:41 AM
type11969   Nice work Dave, looks similar!   Jan 30 2007, 11:52 AM
JerryP   This thread is great and these pictures are very h...   Jan 30 2007, 01:09 PM
dkos   This thread is great and these pictures are very ...   Jan 30 2007, 02:11 PM
type11969   Ha, well I'm lucky in that my garage is the fi...   Jan 30 2007, 01:42 PM
dkos   resale value??? I plan on being burried in mine...   Jan 30 2007, 02:04 PM
rmital   ......... I plan on being burried in mine! m...   Jan 30 2007, 02:08 PM
dkos   so Chris...any new pics? :smash: :welder:   Jan 31 2007, 01:41 PM
type11969   Wow! Dr. 914 defers to me!! Such respo...   Feb 1 2007, 07:45 AM
type11969   Heater tube sheet metal tacked in: http://i19.pho...   Feb 6 2007, 09:25 PM
Johny Blackstain   :clap: Wow!! Kick-ass project & threa...   Feb 6 2007, 10:15 PM
type11969   Thanks Johny! You are welcome to stop by whene...   Feb 7 2007, 08:15 AM
Johny Blackstain   Thanks Johny! You are welcome to stop by when...   Feb 7 2007, 08:24 AM
type11969   Thanks Johny! You are welcome to stop by whe...   Feb 7 2007, 09:13 AM
Johny Blackstain   [quote name='Johny Blackstain' post='860069' date...   Feb 7 2007, 09:23 AM
type11969   Megasquirt is a DIY fuel injection system. I'v...   Feb 7 2007, 09:41 AM
Johny Blackstain   Megasquirt is a DIY fuel injection system. I...   Feb 7 2007, 09:53 AM
michelko   Another one fight the rust!!! :trophy:...   Feb 7 2007, 10:27 AM
type11969   Another one fight the rust!!! :trophy...   Feb 7 2007, 11:14 AM
type11969   Megasquirt is a DIY fuel injection system. I...   Feb 7 2007, 11:12 AM
Johny Blackstain   Chris- let me know regarding Sunday. If not, no b...   Feb 9 2007, 09:07 PM
type11969   pm sent   Feb 10 2007, 09:52 AM
type11969   After a rough, but entertaining weekend, I've ...   Feb 12 2007, 09:20 PM
type11969   Got a little work done here and there over the pas...   Mar 19 2007, 08:01 AM
dkos   Great progress Chris.   Mar 19 2007, 08:29 AM
JerryP   I can't believe you got all that done last nig...   Mar 19 2007, 09:05 AM
type11969   Oh, no, I didn't get all that done last night...   Mar 19 2007, 09:13 AM
Johny Blackstain   :popcorn: :thumbsup: :sawzall: :type: :worship...   Mar 19 2007, 09:30 AM
michelko   Wonderfull!!! Like those picĀ“s. If ...   Mar 19 2007, 12:58 PM
type11969   Michelko- I'm sure there are many 914s out the...   Mar 19 2007, 01:03 PM
michelko   yeah i would like to.. but i need more space to s...   Mar 19 2007, 01:06 PM
type11969   Inner rocker on: http://i19.photobucket.com/album...   Mar 25 2007, 09:18 PM
grasshopper   :bump:   May 3 2007, 05:15 PM
type11969   Been busy with the Beetle, trying to tweak the car...   May 3 2007, 07:28 PM
tdgray   Excellent work Chris... keep it up!   May 4 2007, 12:18 PM
type11969   Wow, haven't touched the teener in quite some ...   Sep 18 2007, 08:47 PM
okieflyr   So did this weekends car events rekindle the flame...   Sep 18 2007, 09:28 PM
type11969   Definitely . . . it was one of the big reasons why...   Sep 18 2007, 09:38 PM
JerryP   Nice work Chris. Glad to see your back on the proj...   Sep 19 2007, 07:57 AM
Johny Blackstain   Chris- was good to finally meet you. Bug looked g...   Sep 19 2007, 08:05 AM
dkos   Nice work Chris. Makes me feel bad about my car c...   Sep 19 2007, 08:06 AM
type11969   Jerry- Definitely still want that front vale...   Sep 19 2007, 08:17 AM
JerryP   No sweat Chris. It's not in my way. In fact I ...   Sep 19 2007, 09:24 AM
- Lo-Fi Version Time is now: 18th April 2025 - 11:15 PM
