> Easy way to check for toe-in?
TonyAKAVW
post Jan 30 2007, 07:26 PM
That's my ride.
I just received tires today to replace my front tires, which have worn on the inside much faster than the outside. My rear tires still have a lot of tread, whereas the fronts are basically bald on the inside. My guess is that its either toe-in or camber. The wheels don't look cambered any more than the back, though the front of the car does sit a bit lower than the back.
So my question is, is there a way to easily check to see if the front has too much toe-in? I was thinking about rigging up some laser pointers or something, but I don't know.
I would like to avoid getting an alignment because later this year I'll be putting on my carerra front suspension. For now I'd just like to prevent premature wear of the tires.
Tony
TonyAKAVW
post Jan 31 2007, 12:34 PM
That's my ride.
I took the wheels and tires in this morning and the guy I gave them to said "You really need to get an alignment this is severe camber wear." So, maybe its camber after all. In any case I'll try to do some measurements at home.
-Tony
- Lo-Fi Version Time is now: 29th April 2025 - 06:34 PM
