Wiring question on a 1.8 l-Jet, FI part of dual relay.... |
jim_hoyland |
Feb 3 2007, 09:38 PM
Get that VIN ? Group: Members Posts: 9,571 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of:
Yellow Red/Black Black |
ClayPerrine |
Feb 3 2007, 10:58 PM
Life's been good to me so far..... Group: Admin Posts: 15,967 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of: Yellow Red/Black Black Yellow - Goes to the 4 pin connection on the left rear of the relay board. Used to close the fuel pump portion of the relay when the starter is engaged. Red/Black - comes from the double relay, goes to pin 12 on the 12 pin engine harness connector. This is the same pin where the white wire for the aux air regulator on the D-jet connects. It sends the power back to the fuel pump circuit from the double relay. There are 2 black wires. One goes to the positive side of the coil (probably the one you are thinking of) and the other goes to the negative side of the coil. Hope that helps. |
jim_hoyland |
Feb 4 2007, 09:05 AM
Thanks Clay.
I know where that yellow wire jumps. I'm in the process of rebuiling a harness from a donar. Jim One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of: Yellow Red/Black Black Yellow - Goes to the 4 pin connection on the left rear of the relay board. Used to close the fuel pump portion of the relay when the starter is engaged. Red/Black - comes from the double relay, goes to pin 12 on the 12 pin engine harness connector. This is the same pin where the white wire for the aux air regulator on the D-jet connects. It sends the power back to the fuel pump circuit from the double relay. There are 2 black wires. One goes to the positive side of the coil (probably the one you are thinking of) and the other goes to the negative side of the coil. Hope that helps. |
ClayPerrine |
Feb 4 2007, 01:18 PM
We are reinstalling the L-Jet FI back onto Doug's car on Sat. I will get someone to take some detailed shots of the harness for you.
Thanks Clay. I know where that yellow wire jumps. I'm in the process of rebuiling a harness from a donar. Jim One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of: Yellow Red/Black Black Yellow - Goes to the 4 pin connection on the left rear of the relay board. Used to close the fuel pump portion of the relay when the starter is engaged. Red/Black - comes from the double relay, goes to pin 12 on the 12 pin engine harness connector. This is the same pin where the white wire for the aux air regulator on the D-jet connects. It sends the power back to the fuel pump circuit from the double relay. There are 2 black wires. One goes to the positive side of the coil (probably the one you are thinking of) and the other goes to the negative side of the coil. Hope that helps. |
jim_hoyland |
Feb 4 2007, 01:31 PM
Thanks. Shoot one showing the bottom of the dual relay too.
We are reinstalling the L-Jet FI back onto Doug's car on Sat. I will get someone to take some detailed shots of the harness for you. Thanks Clay. I know where that yellow wire jumps. I'm in the process of rebuiling a harness from a donar. Jim One branch of the L-Jet ignition harness goes to the left side of a dual relay. What is the funciton of: Yellow Red/Black Black Yellow - Goes to the 4 pin connection on the left rear of the relay board. Used to close the fuel pump portion of the relay when the starter is engaged. Red/Black - comes from the double relay, goes to pin 12 on the 12 pin engine harness connector. This is the same pin where the white wire for the aux air regulator on the D-jet connects. It sends the power back to the fuel pump circuit from the double relay. There are 2 black wires. One goes to the positive side of the coil (probably the one you are thinking of) and the other goes to the negative side of the coil. Hope that helps. |
Lo-Fi Version | Time is now: 6th January 2025 - 03:56 PM |
