3.0 guys - anyone running carbs, what cam? |
Mike D. |
Feb 7 2007, 02:06 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,446 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
I'm looking at possibly getting a 3.0 but it has no F.I. So I would just run it with webbers.
Does anyone out there have this set up now? Are You running the CIS cam or was it changed out to a early T,E or S? Bruce Andersons book says it's an easy 200HP with Webbers (set correctly) and headers, and the stock CIS cam. Any thoughts? TIA, Mike D. |
Racing916 |
Feb 8 2007, 07:12 AM
Member Group: Members Posts: 341 Joined: 16-October 04 From: Binghamton, NY Member No.: 2,959 Region Association: North East States |
I run a 2.7L w/Carbs and I also use "E" cams that replaced the "S" Cams. E Cams will give you more Tourque. The motor has around 240 HP and about 240 ft. lbs. of Tourque. Compression is 10.9 to 1. I did have to replace the pistons, and now they are correctly domed. I would say the "E" cams are the way to go. The motor with S cams before was not as much fun to drive.
Lo-Fi Version | Time is now: 22nd September 2024 - 12:13 PM |
