> Pics of modified stock cooling fans, Optimized for higher RPM use and optimum power
Jake Raby
post Feb 8 2007, 12:24 AM
Engine Surgeon
All of these units are balanced to Kevin Groots E Production 2.0L SCCA engine. We havewent a little above and beyond to do this so he will have a variety of cooling fans that can be used at various tracks due to the track conditions and configuration.
Each of these will be tested on his engine while it's proving it's self in my new lab in just a couple of weeks in preparation of the 2007 SCCA season, his first with MassIVe power.
During testing we'll be comparing the effectiveness of the cooling fan in both temperature ranges and power potential so kevin will have baselines that he can use to choose the best fan for the particular track event be it qualifying or the mac daddy at the Run Offs....
Each of these will be tested both with and without our newest cooling system addition for the 914 engine, the cooling fan velocity enhancement ring. This ring works with any stock fan on any Type 4 fan housing as a bolt on component. It protrudes into the fan inlet and helps to boost the speed of the air entering the fan as well as helping to direct that air into the fan more effectively. The unit pictured is an R&D unit made for me by good ole "spunone" who has become our go to guy for trick test components like this! Thanks man!
I'll be posting data logs from the testing over on my forums in the "Dyno room" section in a couple of weeks..
Jake Raby
post Feb 8 2007, 12:28 AM
Engine Surgeon
Now with the velocity enhancement ring...
I have added an odd pic just to see if someone can guess what I'm working on as well :-)
904svo
post Feb 8 2007, 07:46 AM
904SVO
QUOTE(Jake Raby @ Feb 7 2007, 10:28 PM) *
Defusser ring, used to increase air flow.
my guess
Jake Raby   Pics of modified stock cooling fans   Feb 8 2007, 12:24 AM
Jake Raby   Now with the velocity enhancement ring... I have a...   Feb 8 2007, 12:28 AM
904svo   Now with the velocity enhancement ring... I have ...   Feb 8 2007, 07:46 AM
URY914   Sick. But very cool. I gotta ask why he isn...   Feb 8 2007, 06:28 AM
Jake Raby   Sick. But very cool. I gotta ask why he isn...   Feb 8 2007, 09:47 AM
crash914   hmmmmm 996 gt3?   Feb 8 2007, 06:53 AM
crash914   could be a boxter engine also....   Feb 8 2007, 08:10 AM
ahdoman   Hey Jake, if you ever make it to LA we'll have...   Feb 8 2007, 08:28 AM
BK911   ... so any extra cooling without loosing HP is im...   Feb 8 2007, 09:24 AM
Dave_Darling   Additional airflow requires additional power. ...   Feb 8 2007, 10:14 AM
URY914   Jake, Once again you answer a question completly...   Feb 8 2007, 10:30 AM
groot   The excitement is building........ This is the sea...   Feb 8 2007, 12:03 PM
Aaron Cox   nicework guys   Feb 8 2007, 12:24 PM
Joe Owensby   Just curious. What is the rational for removing...   Feb 8 2007, 09:28 PM
brant   Nice gears kevin... my top gear is also a V   Feb 8 2007, 09:41 PM
Jake Raby   Joe, That fan is a test fan more than anything... ...   Feb 8 2007, 10:03 PM
Jake Raby   BTW- I invested in 4 more pressure transducers for...   Feb 8 2007, 10:08 PM
shaggy   i cut up my fan to look like the second one you po...   Feb 8 2007, 10:17 PM
Aaron Cox   i cut up my fan to look like the second one you p...   Feb 9 2007, 12:10 AM
Bleyseng   i cut up my fan to look like the second one you p...   Feb 9 2007, 10:51 PM
TimT   [hijack} nevermind [/hijack]   Feb 8 2007, 11:34 PM
Joe Owensby   It will be interesting to see the pressures, etc. ...   Feb 9 2007, 10:18 PM
- Lo-Fi Version Time is now: 27th December 2024 - 01:28 AM
