PRO-M Mass Air flow on a 3.2, Does anybody have any experiece with one |
Steve |
Nov 16 2003, 04:11 PM
914 Guru Group: Members Posts: 5,771 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I installed the PRO-M Mass Air flow on my 3.2 in my 914.
The motor idled fine but mid range and high ran rough and cut out. I tweaked the knobs on the tuner module and it no longer cut out. I did not notice any more power and the motor ran kind of boggy. Does anyone have any experience with this conversion? regards, SF Attached image(s) |
SirAndy |
Nov 18 2003, 02:18 PM
Resident German Group: Admin Posts: 41,961 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(sechszylinder @ Nov 18 2003, 11:56 AM) The MAP sensor of the megasquirt efi will not work with a system, which is designed for sensing air mass or air flow , like L-Jetronic or Motronic because megasquirt is based on manifold pressure (Manifold Absolute Pressure) . danke für den link! hmmm, i was under the impression that you can translate manifold pressure into air-flow ... from their web-site: "The MAP sensor is used by MegaSquirt for two separate tasks. First, it is used as a Manifold Absolute Pressure monitor, which monitors the intake tract pressure (absolute), which is a direct (proportional) indication of mass air flow and required fuel." Andy |
Lo-Fi Version | Time is now: 6th January 2025 - 04:59 PM |
