Additional Cooling, Running a 3"- 4" Hose directly onto the fan |
GBallantine |
Feb 8 2007, 11:13 AM
Member Group: Members Posts: 74 Joined: 12-October 04 From: Toronto,Ont.Canada Member No.: 2,930 |
Any race guys ever run a 3 or 4 inch hose mounted off the front air dam or attached near the outside mirror thru the rear fire wall and directed onto the fan? Does it add any cooling effect? Any pics of setups?
GB |
john rogers |
Feb 18 2007, 09:33 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
Probably the most efficient method, with all of the %'s aside is to use fans such as in pict #2 above which is the #22 Wayne Baker car and then use an alternator, specially wound, so it will freewheel until over 4K RPM and then put out the 12 volts needed. There is no fan on the engine and the air ducts blow directly on the cylinders and heads. This setup is terrible for auto-x but GREAT for road racing. When Ron Mistak would bring #22 to the stadium in San Diego, his crew would always have a jumper batt on a cart handy since it would nearly always need jump starts.
Lo-Fi Version | Time is now: 26th June 2024 - 12:35 AM |
