jgara962 |
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California ![]() |
My weekend project is to remove the backpad and rubber pad behind it. So far so good - the two combined weight 26 lbs! I'm going to put down some Dynamat Extreme and then lay a Morph carpet kit over the top.
One question. Do I need to remove all of the glue that is stuck to the firewall from the original pad, or do you think I can just lay the Dynamat over it? What should I use? So far I've tried Goof Off and a razor blade scrapper, but that's going to take a while and I already have a buzz going (IMG:style_emoticons/default/biggrin.gif) Attached image(s) ![]() |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
How did you handle the seat brackets? They look nice btw!
jgara962 |
How did you handle the seat brackets? They look nice btw! I REALLY went back and forth on that one between using the mounting bars that I bought from Corbeau and just mounting the brackets directly to the seats. I ended up mounting the brackets directly to the seats by drilling new holes in them and then using the bolts from the kit. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:21 AM |
