jgullock |
Newbie ![]() Group: Members Posts: 37 Joined: 19-August 03 From: Warner Robins, GA Member No.: 1,045 ![]() |
Long time lurker finally sacking up to ask a question. Here’s the deal – have a 73 914 with a Renegade conversion package (9 inch clutch upgrade) with about 1,000 miles on it. Was driving one day and I noticed the clutch pedal wasn’t working like it was supposed to, had the broken clutch tube symptom. Happened all of a sudden like too. Drilled some holes at the front tube mount point and checked the tube while pushing in the clutch– it was O.K., didn’t move at all. Anyways, I tack welded it through the holes while I was there. From what I’ve found on the site your supposed to have a little bit of slop at the pedal before the cable even engages and applies force to the throwout bearing arm correct? If I set it up like this, with the clutch pedal all the way to the floor I can feel the pressure plate trying to grab the disc – not quite completely releasing. The only way I get this thing to shift smoothly is to have tension in the cable but am I screwing up the throwout bearing and/or pressure plate fingers? Is it normal for this aftermarked clutch setup to have tension in it? Is the cable bad (Terry cable) and acting like a big spring (stretching)? Or perhaps is the pressure plate setup not matched to the travel the throwout bearing provides? WTF??? (IMG:style_emoticons/default/confused24.gif) Any input is appreciated.
Thank you. You friend, Johnny G. P.S. - I ordered a GEMO cable from GPR as a backup and am thinking of putting it in. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Part of the "free play" is the amount the pedal moves when you pull upward on it. Remember, the pedal itself is sprung downward--if the cable breaks, the pedal goes all the way to the floor. So pull up on the pedal to measure free play.
--DD |
Lo-Fi Version | Time is now: 26th June 2024 - 05:39 AM |
