How To: Swivel foot valve adjusters on a 74-76 2.0L? |
JeffBowlsby |
Jan 10 2007, 06:10 PM
914 Wiring Harnesses Group: Members Posts: 8,781 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So those in the know...how is this conversion done? I don't now the specifics so please tell me. I understand that the stock 74-76 2.0L cars use a larger-diameter adjuster and cannot accept the swivel foot adjusters because they are smaller. The needed parts as I understand it are:
* Rocker arms/shaft assemblies from a 1.7L engine * Swivel feet valve adjusters (10mm?) * Shims Is all the above correct? What shims do I need and where are they installed? Is there further machining to do to the rocker arms? All details please...Thanks in advance (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Aaron Cox |
Jan 11 2007, 01:28 AM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
i got mine off ebay and clearanced em to .004" side to side play
914Mike |
Feb 26 2007, 08:59 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
i got mine off ebay and clearanced em to .004" side to side play I just used the Hydro spacers and the shims and spring washers that came with them. The shims go under the rocker stands to give the swivels enough room, I got mine from Bugformance on Capitol Ave, they're hanging on the carded wall on the right as you go in... (I'm sure Jeff knows where this place is.) Either way you need to make custom length pushrods to get the geometry right once you put the 50-60 thou shims under the rocker stands. If you don't set it up so that the first half of the lift is pushing up on the valve stem, and the second half pushing it down, you will get premature wear on the valve guides. The stock length pushrods will be pushing mostly up on the valve stems... |
CHAFF |
Feb 26 2007, 09:19 PM
Member Group: Members Posts: 167 Joined: 13-September 04 From: Regina, SK Member No.: 2,749 |
Could you not just grind the face of the swivel foot down? -L |
Dave_Darling |
Feb 26 2007, 09:33 PM
914 Idiot Group: Members Posts: 15,063 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Could you not just grind the face of the swivel foot down? That would probably go through the hardening on the swivel foot, and get to a part that would wear quickly. It might also weaken the foot so that it breaks after a while... Decking the rockers is a known quantity; they are more than beefy enough in that area to take it. --DD |
Lo-Fi Version | Time is now: 27th December 2024 - 01:36 PM |
