What can I expect? |
Bogaat |
Mar 1 2007, 09:44 AM
Member Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 |
What should I expect from a 2 liter FI engine with 60k original miles? I do not think it has been maintained over the last 6 years or had any real overhaul before that. It seems to run well now, but does has a few leaks. I am planning on pulling it apart to replace the seals. I was thinking about bearings, rings, cam, lifters and a little head work as well, but thought I would ask you guys to see if you have any thoughts. Maybe I can get away with not replacing anything but seals? Bad idea? I would like to put some miles on this thing over the next few years. Thanks all!
rhodyguy |
Mar 1 2007, 10:26 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
1-3k+. dependent on parts, head condition, other machine work, and the amount of work you have to farm out to split the case for a new cam. things add up rather quickly. esp if you make component upgrades *while you're in there*. have you figured out where it's leaking? run a compression and leak down test to determine the engine's weaknesses first.
k |
Lo-Fi Version | Time is now: 25th June 2024 - 04:33 PM |
