dagdal1967 |
What are YOU looking at... ![]() ![]() Group: Members Posts: 372 Joined: 13-March 03 From: Carrollton, Texas Member No.: 423 ![]() |
I (IMG:style_emoticons/default/wub.gif) my 914. This one is really special. Extremely clean, rust free (no really!) and original. I parted with my last one when I really didn't want to and regretted it severely!
However, the car is depressing me! After Clay helped me put the FI back on (which turned in to a mild debacle) she ran like a dream for a while, then the rebuilt feul pump started to "whine". It's internment so I still haven't diagnosed that propperly. Then I put new plugs in (on the recommendation of Clay) and now the damn thing is running like an old Briggs and Stratton Hit & Miss engine. I am NOT mechanical. I never have been. I know enough to diagnose and fix small problems but don't really even have the base knowledge about engines that most all of you guys take for granted. Am I kidding myself trying to own a 914? It seems like the maintenance never ends and after having the car (in running condition) for about a year now, I've barely been able to enjoy 2-3 months of driving! Should I just give up and let someone else who has more know how and mechanical stamina take care of the old girl? Suicidally yours.. (IMG:style_emoticons/default/sad2.gif) Doug |
bperry |
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 ![]() |
Doug,
I'm in Addison. Just around the corner from you. I can drop buy and give you hand. PM me. My guess is that one of your ignition wires is bad. I had a similar problem years ago, after changing out plugs. I seem to recall that some ignition "wires" are not wires at all. They use some kind of paste internally. In my case, the plug connector wasn't making proper contact with the internal paste. I pulled my hair out trying to figure out what the problem was before I replaced the wires. Only thing I can figure is that I accidentally pulled on the wire instead of the connector when removing the plug wire. In another case, it caused a heavy misfire between about 2000 and 2200 RPMs. In that case, it turned out that the engine vibration was causing the internal paste to crack or separate and not fire one of the plugs. Talk about odd.... and painful (and expensive) to figure out since it showed up suddenly after no maintenance and only caused a problem in that RPM range. After that second experience, I now refuse to use ignition wires that are not made from real wire. PS, I've got a set of wires, I could bring over that we could try on your engine to see if that is the problem. ---- bill |
Lo-Fi Version | Time is now: 26th June 2024 - 05:20 AM |
