TimAZ |
Newbie ![]() Group: Members Posts: 20 Joined: 19-March 03 From: Phoenix, AZ Member No.: 442 ![]() |
I have a 914-6 six with stock size front rotors and four piston Brake Tec calipers. Does anyone know of a larger diameter rotor that will fit these calipers and still fit inside a 16" wheel? You can email me at thannum@cox.net Thank you for any help.
rfuerst911sc |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States ![]() |
Mueller what are the width and diameter of that rotor? Were you happy with the performance? What did you run on the rear of the car? Any balance issues? Did you use a adjustable pressure regulator? What size master cylinder? Thanks
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Mueller what are the width and diameter of that rotor? Were you happy with the performance? What did you run on the rear of the car? Any balance issues? Did you use a adjustable pressure regulator? What size master cylinder? Thanks 12.19" x .810" sold the car to which these were supposed to go onto....they are just collecting dust in my tool box (IMG:style_emoticons/default/sad.gif) originally Mazda RX7 Turbo calipers had been planned to be used with them and I would have tackled the other issues as I got to them. Only real differance between these rotors and pre-84 911 rotors (besides being lighter) is the OD is a little over an inch larger on these |
Lo-Fi Version | Time is now: 28th June 2024 - 02:56 PM |
