jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
i noticed that a wire going to the coil sends a signal to the light - is this correct or could this be my problem causing the flickering?? if i disconnect this wire the light goes out. jim
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
i noticed that a wire going to the coil sends a signal to the light - is this correct or could this be my problem causing the flickering?? if i disconnect this wire the light goes out. jim If you are seeing that, then you need to put a mechanical oil pressure gauge on the car and check the pressure with it. If the readings are OK, then replace the sender. Otherwise you may need some engine work. |
Lo-Fi Version | Time is now: 25th June 2024 - 05:37 PM |
