Starter Question, High Torque or regular |
pin31 |
Mar 12 2007, 11:27 AM
Member Group: Members Posts: 398 Joined: 30-January 07 From: Newport, Rhode Island Member No.: 7,492 Region Association: North East States |
I think my starter died this weekend. Everything was fine last weekend when I went for a nice drive. Alternator charging good, new battery, no shorts or bad grounds etc..
Turn key and get the solionid click. I have checked the battery (12.35V) cleaned ground connection and terminals, cleaned connections on starter, cleaned connection to transmission ground strap...every thing looks good. Also I have bypassed the '74 seatbelt relay (a while back) so thats no longer in the starter circuit. Other than the ignition switch (which I am buying a spare to have on hand) is there anything else I've overlooked?? I'm thinking it's the starter and I'm about to buy one. Do you reccomend the rebuilt Bosch or the new high torque ones (lifetime warrenty)? Is there anything I need to be aware of with the high torque unit (i.e. will it bolt right in etc..)? Thanks, Tim |
pin31 |
Mar 13 2007, 07:18 AM
Hi Gang, thanks for all the suggestions.............. I try them (hopefully tonight).
How about the ignition switch? Dr914 states in his 700 Tips book "if the red and green lights (alt and oil pressure light) go out when turning the key to the start position (which mine does) and the car does not start, then the ignition switch is bad". What do you think? The results of the screwdriver test (if it works) would lead me to think the ignition switch. Should it be restated: ".......and the car does not start, then the ignition switch is bad and/or the starter is bad"????? Just another thought ......need to get under the car tonight. |
Lo-Fi Version | Time is now: 26th September 2024 - 12:10 PM |
