yarin |
'14-X'in FOOL ![]() ![]() ![]() Group: Members Posts: 988 Joined: 13-May 03 From: Guttenberg, NJ Member No.: 693 Region Association: North East States ![]() |
Does anyone have a writeup on how to install a CV joint on the axle?
I'm uncertain of which goes first and in what direction. Here is a pic of the kit: (IMG:http://www.pmbperformance.com/i//CV_Joint_Kit.jpg) Thanks |
1.8914 |
Newbie ![]() Group: Members Posts: 25 Joined: 16-September 04 From: Stillwater, OK Member No.: 2,770 ![]() |
I'm at about the same stage you are in the process...I'll be watching to see how you come out. I bought the same kit x 4 from PMB. I'm sure if you called Eric he'd be happy to talk everything over with you. I pulled out 1 new CV and it was hard to move but didn't mess with it much since it doesn't have grease yet.
Mine has the non-splined washers with the thick clip. Any problem with reusing the old washer to avoid pressing the cv to flatten the washer? I don't see much issue with reusing that washer (although I'm not the foremost expert on such things). Also my kits only came with the one snap ring type of clip and mine car had the other type on it. Did you do the bearings as well? |
Lo-Fi Version | Time is now: 26th June 2024 - 06:53 AM |
