watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
I'm going to install the foam and vinyl on the top of the dash, between the dash top and the windshield. I've read several of the previous posts, with several recommendations of using 1/8" foam. Should I cut the foam to the exact dimension of the dash or should I trim it 1/4"? I understand that I'm suppose to glue the foam down, and only glue the edges of the vinyl to the metal frame, not to the foam.
Any other suggestions? -- Rob |
watsonrx13 |
Thanks for the responses and the pics....
Now, is the dash/windshield rubber seal still available, if not, what is the alternative? -- Rob |
tyler |
Member ![]() ![]() Group: Members Posts: 335 Joined: 24-September 03 From: southern california Member No.: 1,192 ![]() |
It's available but I bought one of the cheap ones and it wouldn't lay down and fit right so I returned it. I bought the good one which was about $100 and it fits great. I have an extra one (I think it's a good one) I'll give you a deal on if you're interested.
I put the vinyl on and left the old foam and just glued the edges of the new vinyl after templating it from the old piece. It would have been better to put new foam on in the exact same places as stock. One thing to watch out for is where the vinyl goes under the dash cover in back of the instruments. If there's not enough foam there it will leave a gap because the vinyl will lay too flat. So I think it's very important to place the dash onto the vinyl for a test fit when you're installing the vinyl or you could be in for a surprise later on (happened to me) when you re-install the dash. Now, is the dash/windshield rubber seal still available, if not, what is the alternative? -- Rob [/quote] |
Lo-Fi Version | Time is now: 8th July 2024 - 01:37 PM |
