> Superlite 15x7 25+ offset 4 lug 4x130 wheels, for those of you looking for something different
Gint
post Mar 26 2007, 07:32 PM
Mike Ginter
I had half a dozen titles for this thread in my head...
It's finally time to mount the Superlite wheels I bought in June 06. Mike Z was given a second chance offer from ebay when the auction didn't make reserve. He offered them up and I grabbed it. I bought them significantly cheaper than Pack Racing currently offers them for on their website. So it was worth it. Here's the original thread There were many questions (and even a little mis-information) in that thread. I'll answer quite a few here since I now have the wheels have tires mounted on them and I'm about to use them.
BTW - 914world member Nick Mironov has a thread about his Superlite wheels. Nick's superlite wheel thread . Nick, you want to read this thread and possibly talk to Pack Racing about a set of inserts with a proper conical lug bolt/nut seat.
This post has been edited by Gint: Jan 2 2013, 06:26 PM
Gint
post Mar 26 2007, 08:52 PM
Mike Ginter
Now, this is a piece of info that anyone wishing to order Superlite wheels for a 914 needs to be aware of. Be certain that you tell them that you are purchasing wheels for us on a Porsche 914, (and provided your car is a stock configuration) it uses 14x15mm lug bolts, a 4x130 bolt circle and the hubs are not hubcentric. This should be enough information for them to know what type of insert to install in the wheels prior to shipment. I believe they have not yet supplied many of these wheels for a 914, so they are working out some kinks.
On to the details...
Apparently, Pack Racing modifies these wheels and adds inserts into the mounting holes to provide the correct size lug bolt/stud hole and a conical seat. The bolt hole is 17mm, so a 14x1.5 lug bolt or stud will float in the hole. And since these wheels are lugcentric, there is no way without these inserts (or a reasonable substitute) to locate or center the wheel.
I'll spare you the long story, but with the help of Terry from Pack Racing, we figured out that these wheels had shipped without the inserts. I'm going to either get a set of these inserts from Terry or make some of my own. I haven't really decided yet. If P.R. will send me the inserts for free I'll liekly go ahead and get a full set. I'll update this thread when that's been determined.
The lug bolt/nut mating surface as supplied from the manufacturer is flat.
Close up
Insert rear view
Insert front view
This post has been edited by Gint: Mar 28 2007, 10:29 PM
Gint   Superlite 15x7 25+ offset 4 lug 4x130 wheels   Mar 26 2007, 07:32 PM
Gint   I thought I was getting 2 wheels with 25mm+ offset...   Mar 26 2007, 08:42 PM
Aaron Cox   let me interject a little. offset is a pretty usel...   Mar 26 2007, 08:50 PM
Gint   let me interject a little. offset is a pretty use...   Mar 26 2007, 08:58 PM
Gint   Now, this is a piece of info that anyone wishing t...   Mar 26 2007, 08:52 PM
nebreitling   Tires... I've now gone from running the fatt...   Mar 26 2007, 10:09 PM
Gint   Hoosiers are 8.7" across! There's on...   Mar 26 2007, 10:11 PM
Joe Ricard   Hmm My Hoosiers are 11" across. with a tre...   Mar 27 2007, 02:10 PM
Tobra   More tires in 195-55-15 than you would think; nice...   Mar 27 2007, 09:22 PM
Borderline   How much do these "superlite" wheels wei...   Mar 27 2007, 11:40 PM
Gint   How much do these "superlite" wheels wei...   Mar 28 2007, 08:43 AM
sean_v8_914   vcb   Mar 28 2007, 01:18 AM
sk8kat1   I really like those!! so what is the prop...   Mar 28 2007, 11:24 AM
Gint   Mine are 15x7 25mm+ offset. IMHO, In a 15...   Mar 28 2007, 11:39 AM
sk8kat1   Mine are 15x7 25mm+ offset. IMHO, In a 15...   Mar 28 2007, 11:57 AM
Aaron Cox   [quote name='Gint' post='880887' date='Mar 28 200...   Mar 28 2007, 12:30 PM
Gint   ...so those 15" opions I would be able to d...   Mar 28 2007, 12:36 PM
Aaron Cox   [quote name='Aaron Cox' post='880909' date='Mar 2...   Mar 28 2007, 12:40 PM
cuca914   Mine are 15x7 25mm+ offset. IMHO, In a 15...   May 10 2007, 07:07 PM
Gint   [quote name='Gint' post='880887' date='Mar 28 200...   May 13 2007, 03:08 AM
sean_v8_914   good info about backspacing and offset here   Mar 28 2007, 11:53 AM
Gint   good info about backspacing and offset here Tha...   Mar 28 2007, 10:48 PM
sk8kat1   arron if you are trying to make me do my " ho...   Mar 28 2007, 12:50 PM
Aaron Cox   not what i meant. i believe all the info was is in...   Mar 28 2007, 12:53 PM
sk8kat1   not what i meant. i believe all the info was is i...   Mar 28 2007, 01:33 PM
nein14   here are my 15 x 8 on yoko advanta r 032 soft comp...   Mar 28 2007, 06:41 PM
Aaron Cox   i got the same ADVAN A032R's in harder compoun...   Mar 28 2007, 06:46 PM
nein14   I actually work with Barry the owner of Pack Racin...   Mar 29 2007, 08:07 AM
Gint   I actually work with Barry the owner of Pack Raci...   Mar 29 2007, 08:28 AM
Gint   I talked with Terry from Pack Racing Friday. Even...   Apr 2 2007, 02:48 PM
Gint   I'm finally getting around to installing these...   Apr 20 2007, 01:00 PM
Gint   Dammit I can't win! So I took the wheels/...   Apr 20 2007, 06:11 PM
ChrisNPDrider   :( Those are press in inserts to convert mag/flat...   Apr 20 2007, 06:25 PM
Gint   Yes. Pack Racing normally installs these inserts...   Apr 20 2007, 06:31 PM
73Phoenix20   Interesting info... Does anyone know if Mini Lite ...   Apr 20 2007, 07:49 PM
jim_hoyland   Gint, Thanks for the lesson; Good Stuff !   Apr 20 2007, 09:32 PM
Gint   It's been a long road... My $360 deal on...   May 6 2007, 09:38 PM
TROJANMAN   :clap: That car looks faster already........... ...   May 7 2007, 12:23 AM
Gint   :clap: That car looks faster already........... ...   May 7 2007, 05:13 PM
Ferg   Those look fantastic! :headbanger: Ferg   May 7 2007, 09:29 AM
boxstr   The best classic look in an aftermarket wheel. CCL...   May 7 2007, 10:01 AM
majkos   G-man,I'm behind you! :headbanger: I...   May 10 2007, 09:10 PM
JPB   Them there are perdy. :beer1:   May 13 2007, 07:05 AM
orcadigital   Looks good Gint! My wheels still rock, too ba...   May 13 2007, 12:12 PM
sixnotfour   Gint, some other 15inch wheels weights 5 lug Ma...   Jan 2 2013, 12:30 PM
Gint   Cool. Good data. You should list what kind of wh...   Jan 2 2013, 12:36 PM
sixnotfour   Done   Jan 2 2013, 12:40 PM
Gint   Thanks Jeff! Formatted a tad.   Jan 2 2013, 06:25 PM
last337   I am actually looking at putting the bfg g-force s...   Jan 2 2013, 06:56 PM
Gint   They should be fine on a stock alloy wheel.   Jan 2 2013, 09:24 PM
sixnotfour   Found these :D   Jan 29 2013, 08:27 PM
Gint   Those... are... awesome!!! Thanks...   Jan 30 2013, 06:56 PM
BigFour1973   awakening an old thread. If someone could tell me ...   Oct 19 2016, 05:16 PM
Kansas 914   So you are going 7" and 8" and keeping i...   Oct 20 2016, 07:57 AM
BigFour1973   So you are going 7" and 8" and keeping ...   Oct 20 2016, 12:45 PM
Kansas 914   Yes, that's the plan. Do you recall the offs...   Oct 20 2016, 03:03 PM
horizontally-opposed   The wheels are just sitting in the garage - let m...   Oct 20 2016, 03:21 PM
Kansas 914   The wheels are just sitting in the garage - let ...   Oct 20 2016, 06:52 PM
horizontally-opposed   I have Hankook Ventus 2 tires on the car now. Goo...   Oct 20 2016, 08:43 PM
Kansas 914   How were the BFGs on a 914? That's what I am...   Oct 21 2016, 07:16 AM
BigFour1973   Yes, that's the plan. Do you recall the off...   Oct 20 2016, 04:04 PM
Kansas 914   [quote name='Kansas 914' post='2413822' date='Oct...   Oct 20 2016, 06:55 PM
BigFour1973   [quote name='Kansas 914' post='2413822' date='Oc...   Oct 20 2016, 07:02 PM
horizontally-opposed   Ah, so the car was wearing those tires when you go...   Oct 21 2016, 08:30 PM
Gint   Ah, so the car was wearing those tires when you g...   Sep 25 2020, 10:05 PM
Eric_Shea   Ah, so the car was wearing those tires when you g...   Oct 26 2020, 01:17 PM
horizontally-opposed   ^ Super cool, Gint! Center caps are one of th...   Sep 25 2020, 11:04 PM
Gint   Jeff gets all the credit. He made those remotely ...   Sep 26 2020, 07:52 AM
20 User(s) are reading this topic (20 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 24th November 2024 - 07:53 PM
