Clutch Issue, Help! |
bd1308 |
Mar 29 2007, 09:54 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
OK, the clutch acts liek its slipping (not engaging fully when pedal released) *ONLY* when driving for longer periods of time.
Is it possible that the clutch is adjusted too far, but not far enough to cause trouble when cold?? also, is it logical that the clutch would ever tighten??? Or maybe the pressure plate is dead? |
So.Cal.914 |
Mar 30 2007, 12:13 AM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Depends on how you drive, could be warn out. If it were me I would pull it
apart first and look at the FW, mic it and see if it has been cut to much and then warn to the point of no return. What you will pay for a CP and PP you can get a good used FW. Worth a look see before you lay out cash. |
Lo-Fi Version | Time is now: 18th June 2024 - 06:54 AM |
