type11969 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States ![]() |
I'm trying to get my Dell 40s set up properly and I'm currently adjusting the pump volume. In the dell tech manual it states that .4-.5ccs should be released for every two throttle pulls for a 1600cc engine. I can only get ~.2ccs for two throttle pulls at max pump stroke. Would changing the pump jet actually change the volume? I don't see how it would. I'm running a 45 for a pump jet, certainly open to suggestions! Also, suggestions regarding how much more pump volume I should be pushing for an 1800cc, pretty mild with 8.2:1 CR and a web 86 over the .4-.5ccs for a 1600?
Thanks, Chris |
type11969 |
I've been under the impression that I will be fine, I think it comes down to venturi selection. I'm running 32mm vents, if I was running the largest that a Dell 40 could fit, then yes, it probably would be too much.
-Chris |
Lo-Fi Version | Time is now: 24th June 2024 - 11:36 PM |
