PinetreePorsche |
Member ![]() ![]() Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 ![]() |
914 gang: There's a new posting on a less "worldly" 914 club site, featuring Otmar Ebenboech, the power behind Electro Automotive, which makes the "VoltsPorsche" electric conversion kits, and the electric early-Rabbit kit as well (see his 914 at http://www.youtube.com/watch?v=Yl9uejKnMFQ --his does 1/4 mi in 13-something and top speed at 140 mph!. Good interview.) This could become a VERY important source of mobility for some of us should the Saudi "King" either move to a radical position (see his condemnation of the US in today's -Mar 29- papers) or, worse, be overthrown by the Wahabbists who control the madrassas in Arabia. Or war with Iran, now or later! (Or revolution in Nigeria, or an angry Hugo Chavez transferring most of his sales to China, etc.) SO: HOW ABOUT A 914 "HYBRID" ?
For those interested in cleaner power and keeping our cars on the road further into the new century, could hybridize the 914 as follows: Keep a small motor-- the 1.7, or even replaced with a 1500 squareback motor-- set up for max mpg. Should be able to get near 45 mpg. (Or better yet, a small clean "new" diesel if we could get those that are made by VW for European sales--like out of wrecks, to keep cost low.) THEN: Put in an old-Rabbit front end, with the volts-Rabbit kit attached, in place of the whole 914 front end. (Yeah, probably a little fabrication of steering linkage needed.) For long range driving--trips: cruise on electric throttle, add fossil power on uphills, passing. Drained batteries after long mileage, idling in traffic jams or after doing extra errands?? -Go fossil till you get home. Commute on ELECTRIC ONLY. Those in cold climates could leave the boxer motor idling, and run the heater air over the exhausts with little loss. (And those who have to have AC, run the motor at idle with a bigger belt-pulley for the compressor--modern compressors don't steal much power anyhow.) If you want to show off at a stop light, -use dual power: independent f and r power (might need balance/tuning). Use Otmar's smaller (no 13 sec. 1/4 mile unless you use dual power) motor option to keep battery requirement as modest as possible. And there'd be no fancy electric braking like Prius, and no fancy extra controls for that). Just a double gas pedal--the one you've got and a second thing, maybe hanging down from above, able to be moved into place with some kind of slide-lever. Issues, as I see it: A bit of structural fabrication/ welding to accept the slightly alien Rabbit front end/ steering/ motor ass'y. Maybe a modification to the orig gas tank--make it smaller, with batteries in part of that area. Additional battery placement? - more batteries over the r. axle, just behind the existing motor/trunk wall, presumably scatter others around. And if much of the front trunk is lost to the electrics,--its OK, we've got some trunk in the back, even with batteries. Final issue: how much battery weight (and cost!) will be needed for this mixed system? ASK OTMAR-- his interview says the lithium is getting cheaper and more long- lasting, finally, after over 25 years in development. What do people think about the idea? And what does Otmar think, in particular, building on his experience? Anyone interested in making the first one--maybe he'll support you with stuff at cost. [And Otmar--are there any volts-Porsches or -bunnies that you've sold here in the mid-Atlantic area for me to look at?] This could make the 914 the car of the next 35 years! Lets talk it over. -Chris, in DC 'burbs |
wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
QUOTE Batteries are the big problem. Lead acid is heavy Not only that...but these new Enviro-Natzi new fangled cars are bad for the environment. Where do you dispose of the batteries when the car is totaled or worn out? I hope Al Bore isn't listening. |
racunniff |
volt914 ![]() ![]() Group: Members Posts: 172 Joined: 21-August 06 From: Fort Collins, CO Member No.: 6,705 Region Association: Rocky Mountains ![]() |
QUOTE Batteries are the big problem. Lead acid is heavy Not only that...but these new Enviro-Natzi new fangled cars are bad for the environment. Where do you dispose of the batteries when the car is totaled or worn out? I hope Al Bore isn't listening. Can't tell if you're joking or not, but you don't dispose of lead-acid batteries, you recycle them. True of your starter battery, too. Note the special place your landfill has you place car batteries... Disclaimer: I'm building one of the Electro-Auto AC Voltsporsche kits as well... an extreme solution to the "gas smell in the cabin" problem (IMG:style_emoticons/default/laugh.gif) |
914Mike |
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 ![]() |
[quote name='racunniff' date='Mar 30 2007, 07:54 AM' post='881617']
[/quote]Disclaimer: I'm building one of the Electro-Auto AC Voltsporsche kits as well... an extreme solution to the "gas smell in the cabin" problem (IMG:style_emoticons/default/laugh.gif) [/quote] I'm turning my '74 to an EV as well, using the ElectroAuto Light AC vehicle kit. Saved a bit of $$ not getting the larger torsion bars and springs I already have. Plus the VoltsPorsche kit comes with a huge side graphic I don't want (at least the DC kit did). After looking at Otmar's battery layout, (Following in the footsteps...) I decided it would be better to keep the COG as low as possible, and to use sealed batts. (Rust is something I do NOT want to deal with AGAIN!) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) 12 12V's is 144V, vs 18-8V's or 20 6V's (like the DC kit), but the real difference is in the mass. The 12V weighs about 53.6LBs for group 24 (643.2 LBs) The 8v batts weigh 64.5 or 69 LBs each (1161 or 1242 LBs. Half of those go in front, taking up the spare tire well and the gas tank well, with some of the rest mounted ABOVE the motor in a side-to-side box. All the boxes have to be sealed and ventilated during charging to prevent hydrogen buildup, so a bit more weight there too. My setup has 3 12V's in the front fuel tank well, and 9 mounted around the motor, none higher than the top of the motor. Open racks with just a layer of insulation for padding. It should still handle like a 914! (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving-girl.gif) Range will be limited to about double my daily commute, so the batts should last a while, hopefully. (IMG:style_emoticons/default/av-943.gif) Check out my post on RoadGlue for pics, I'll try to add some more when I get a chance. http://www.roadglue.com/forum/showthread.php?t=62 (IMG:style_emoticons/default/happy11.gif) Attached image(s) ![]() |
Lo-Fi Version | Time is now: 21st June 2024 - 02:32 PM |
