914 V8 timing question, How to find TDC |
jmmotorsports |
Apr 5 2007, 09:22 PM
Member Group: Members Posts: 308 Joined: 15-August 06 From: Kelso,Wa. Member No.: 6,658 Region Association: Pacific Northwest |
Since there are no timing marks on the balencer I figured I could use the valves to find TDC. I have a stop in #1. #1 Both valves are closed. #8 both valves are closed. #4 exhaust is closed,intake is about 1/2 open. I am thinking that should be TDC on #1. Fireing order is 1 8 4 3 6 5 7 2 Can any of the chevy experts out there tell me if I am right or wrong or if there is a better way to do it.
Thanks, Jerry |
skline |
Apr 5 2007, 09:30 PM
Born to Drive Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
I would mark the flywheel with the timing cover off, when both valves are closed on number 1 in the compression stroke and the marks line up on the timing gears, you mark the flywheel so it can be seen on top of the transmission hole. That is just how I do it. Others may have a different way?
Lo-Fi Version | Time is now: 20th September 2024 - 04:51 PM |
