> Heater for Water cooled 914s, As promised, here are the pics
marks914
post Apr 6 2007, 12:41 PM
Here are the pics of the prototype. If there is any interest, this may be one of my next produts.
It hets pretty cold here in Michigan, its 26F right now and I do need a heater. I had a heater under my dash and I got tired of looking at it so I came up with this.
It uses the stuck heat/fan controls on the dash. The fan works in the usual way and the red heat director lever actuates the water control valve to control the temp of the heat exchanger.
Mark
marks914
post Apr 6 2007, 07:11 PM
Andys-
Yes, my heater lines run inside the longs back to the engine
Propricer-
Feel free to use my stuf in your book. Check out my website listed in my signature for my gaues and stuff.
I do not tap off the lines to the radiator for a couple of reasons.
I like to keep water going through the engine when the t stat is closed. You may have noticed the return hole on the block where the water pump was is usually blocked by the new coolant line fittings. Keeping coolant flowing through the engine always helps to prevent cavitation and aids in expelling any air pockets.
My water pump has a provision for a heater suction side and I come off of the engine in the stock location on the manifold. I also have a small return line from the high side to the low side to keep some coolant flowing even when the t stat and heater control valve are closed.
I was thinking of making a kit for this conversion, I will test it next week when I get back home.
Mark
marks914   Heater for Water cooled 914s   Apr 6 2007, 12:41 PM
marks914   Here is one of the heater control valve. Does any...   Apr 6 2007, 12:44 PM
euro911   Here is one of the heater control valve. Does an...   Apr 7 2007, 02:47 AM
quadracerx   That is COOL.....When will it be available....I WA...   Apr 7 2007, 03:40 AM
marks914   Here is the pass side As you can see, the origina...   Apr 6 2007, 12:45 PM
Andyrew   Thats what I was going to do!! Cool! ...   Apr 6 2007, 01:10 PM
andys   Mark, Are the heater hoses routed through the ori...   Apr 6 2007, 02:35 PM
So.Cal.914   Very Cool, nice job.   Apr 6 2007, 02:49 PM
propricer   NICE job Mark ... I'm envious !!! ...   Apr 6 2007, 03:20 PM
marks914   Andys- Yes, my heater lines run inside the longs b...   Apr 6 2007, 07:11 PM
Bigbohr   My water pump has a provision for a heater suctio...   Apr 12 2007, 10:02 PM
marks914   My water pump has a provision for a heater sucti...   Apr 14 2007, 06:29 AM
skline   That is sweet, I will be needing one of those in m...   Apr 7 2007, 02:06 AM
marks914   thanks for the input everyone. If i were to offer ...   Apr 10 2007, 10:30 AM
drive-ability   Here are the pics of the prototype. If there is ...   Apr 10 2007, 10:50 AM
Porcharu   thanks for the input everyone. If i were to offer...   Apr 10 2007, 01:33 PM
soloracer   I would like one of everything as well. Let us kn...   Apr 12 2007, 01:11 AM
PinetreePorsche   Yeah--where do you get the actual exchanger? A...   Apr 12 2007, 09:10 AM
Eric_Shea   Very clean job. :trophy:   Apr 12 2007, 09:15 AM
bd1308   I was wondering if oil could also be used for this...   Apr 12 2007, 09:17 AM
marks914   The heat exchanger is new. It will use any liquid...   Apr 12 2007, 09:45 AM
bondo   Add an AC evaporator, and I'll be interested t...   Apr 12 2007, 06:00 PM
pdlightning   Add an AC evaporator, and I'll be interested ...   Nov 5 2011, 07:19 PM
fiid   I'm interested :)   Apr 12 2007, 08:29 PM
marks914   Finally got the sway bar and the tank in, fired it...   Apr 17 2007, 10:29 AM
MecGen   Hey Great Work ! :thumbsup: I am pretty su...   Apr 17 2007, 06:32 PM
soloracer   Any updates on this set up?   Jul 23 2007, 11:20 PM
914nerd   Thats what I was going to do!! Cool! ...   Jul 24 2007, 04:46 PM
pjhaun   Here are the pics of the prototype. If there is ...   Jul 25 2007, 09:01 AM
marks914   The heaters are coming, probably this fall, mid Se...   Jul 25 2007, 09:10 AM
mike_the_man   Any updates on this? I'm planning to start co...   Oct 24 2007, 12:51 PM
joefri187   Yes, Updates please!!!! Winter is...   Nov 14 2007, 04:05 PM
budman5201   Has anyone ever thought of using a Water to Air in...   Nov 17 2007, 12:21 AM
partwerks   Seems like in the past I had seen a 914 member tha...   Nov 5 2011, 08:03 PM
pdlightning   Seems like in the past I had seen a 914 member th...   Nov 5 2011, 10:03 PM
partwerks   I'll have to crawl around under there and take...   Nov 5 2011, 10:52 PM
type47fan   >four year old thread and Mark S. hasn't ev...   Nov 6 2011, 04:32 PM
partwerks   Guess mine is already set up to divert the air fro...   Nov 6 2011, 05:00 PM
speed metal army   Couldnt a guy make some Heat exchangers for the V8...   Nov 6 2011, 06:16 PM
kg6dxn   Couldnt a guy make some Heat exchangers for the V...   Nov 6 2011, 06:31 PM
3d914   I was planning to put one of these into one of t...   Nov 6 2011, 07:19 PM
ruby914   I was planning to put one of these into one of ...   Nov 20 2011, 02:00 PM
speed metal army   Couldnt a guy make some Heat exchangers for the ...   Nov 6 2011, 10:56 PM
3d914   ruby, Its from this catalog. You want page 191. I...   Nov 29 2011, 09:37 PM
ThinAir   Its from this catalog. You want page 191. I belie...   Nov 29 2011, 11:49 PM
3d914   Ernie, that's basically what I had in mind, ex...   Dec 3 2011, 06:34 PM
partwerks   The Renegade Hybrids under dash unit has the capab...   Dec 3 2011, 06:56 PM
BRAVE_HELIOS   I have a 71 Chalon with a SBC. When building the c...   Nov 7 2014, 11:28 PM
BRAVE_HELIOS   I have a 71 Chalon with a SBC. When building the ...   Nov 8 2014, 03:37 PM
Mike Bellis   Sorry, I didn't see the question. Yes, in theo...   Nov 8 2014, 04:45 PM
BRAVE_HELIOS   Sorry, I didn't see the question. Yes, in the...   Nov 10 2014, 10:27 PM
BRAVE_HELIOS   Sorry, I didn't see the question. Yes, in the...   Nov 17 2014, 11:30 PM
Mike Bellis   Pressure differential. it will flow. This is where...   Nov 17 2014, 11:53 PM
37 User(s) are reading this topic (37 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 11th January 2025 - 11:55 AM
