jjs3rd914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 8-August 04 From: Sarasota, FL Member No.: 2,476 ![]() |
It all started when wanting to reinstall the battery tray back in stock position. A PO had put battery in rear trunk and fiberglassed over the "hell hole". Of course the more we dug the worse it got. We have completed the upper area repair inside engine compartment and now ready to install the Restoration Design (RD) outer clamshell overlays. All the major repair threads show the removal of the lower portion of the fender get full access. We really do not want to do this unless this is the only way to correctly install the pieces so they will work as designed.
Has anyone installed the RD overlays (or Brad's system) without cutting away the fender for access? If so how did you do it? It would appear that a very small MIG gun (anyone know of such a tight area gun?) would help, but one still would not get to all the critical areas that need welded inside the fender. Are we indeed doomed to cut the fender piece, reweld and repaint? The car was just painted by the last PO. Thanks, and thanks to all the previous posts on repairs. jjs3rd914 |
jjs3rd914 |
We already have removed the door threshold sill and are in the process of fitting the clamshell overlay. As we pointed out in our inital post the welding of the top of the overlay inside the fender is going to be a challenge. It looks like if the rear trailing arm and suspension are removed it would allow one to sit inside the fender well and take a stab at the welding (if one is right handed). The car is on a four post lift. Another issue is the removal of the upper portions of the remnants of the old jacking plate (new ones will be installed) as they are at the tighest spot.
Dr. 914 or anyone else, we would be very interesed in the detailed technical instructions referenced to guide us through this. In fact just today we ordered the triangle supports from AA to reinstall the sill correctly. Thanks, jjs3rd914 |
Lo-Fi Version | Time is now: 26th June 2024 - 07:34 AM |
