skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
My new project car is 100% rust free.......................
I weld in the chassis stiffening kit yesterday and all went pretty well, removed the undercoating to expose the perfect rust free metal underneath so welding was no problem at all, except I cant see as good as I used to. (IMG:style_emoticons/default/smile.gif) I get done with that and decide to strip the paint around the dent in the rear drivers quarter panel and start removing the dent in it. Well, the dent had some bondo already around it, all around it actually and then I notice the whole fender has bondo on it, all over it. I scrape, grind and make this huge mess of white dust everywhere to find out the panel was shaped entirely with bondo. I knew the rear quarters were both grafted from other cars as one is yellow on the inside and the other one is a bronze color. On the side of my house, I have somehow kept and entire rear quarter panel from another car but had forgotten about it. My option is to try to make the existing panel straight again or cut it off and replace it making sure it is fitting properly. Which is something else I found when removing the bondo from the car. See the pictures below and take note of the door gap and where the steel ends. You can clearly see the line. What would you do in this situation? Cut the panel off and start over? Just get it as straight as you can and bondo the rest? I am open to suggestions. Attached image(s) ![]() ![]() ![]() |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
get it down to all metal.
I find that a propane torch is faster than a sander... Do all the safety precautions (If I did not say that, someone would chime in, steal the thread and talk about it anyways...and I know your a big boy) Anyways... The front part of the fender, think about a scissor jack, and two custom built bucks, one to spread the wieght of the scissor jack, and the other is pushed up against the back of the fender...you can push it out, and hit with a hammer to get it pretty close to original.. Its worth a few hours to try anyways..if at that point you just cant get it back, or loose patience with the metal beating process...start up the drill and take it off. I suspect that it will take quite a bit of time to remove and replace it, and get all the gaps correct, but certainly can be done. I would rather beat the fender to as close as I can get it..bondo works fine if its thin..then paint .. Rich |
Lo-Fi Version | Time is now: 25th June 2024 - 12:13 AM |
